Are these brake lines worth $50 more? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 03-29-2009, 10:45 AM Thread Starter
Flyin5-o's Avatar
I'm doing the brakes on my '85 GT and was was wondering what the difference is between the braided line kits from Maximum Motorsports (P/N MMBK1P) for $121.50 and Russell set for $75.99 outside of the fact the MM ones cost $50 more? Are they worth $50 more or should I just go with the Russell ones?
http://www.maximummotorsports.com/
http://www.jegs.com/i/Russell/799/693010/10002/-1
Flyin5-o is offline
post #2 of 12 Old 03-29-2009, 11:00 AM
mike06tr's Avatar
I bought the MM upgrade kit for my 93lx. New pads, shoes, and thge stainless lines. Man it was a night and day difference.
Get the whole kit you won't be disappointed.
Cheaper than VHT and works great.
So sticky it will practically pull your shoes off, just like the movie theater
floor..
mike06tr is offline
post #3 of 12 Old 03-29-2009, 12:08 PM
I'd be perfectly happy with the Russell ones.
Patrick Olsen is offline
post #4 of 12 Old 03-29-2009, 02:41 PM
85GTVince's Avatar
Originally Posted by Flyin5-o View Post
I'm doing the brakes on my '85 GT...
You probably know this but neither of those kits will work for a stock '85 GT.
Those kits are designed for the '87-'93 V8 brakes.
If you have done the brake upgrade to the '87-'93 V8 brakes then I would use the Russell kit.
--Vince
+ Jalape√Īo Red 1985 Mustang GT, 347 in^3, Canfield heads, 650DP, X-Celerator, & 1-3/4" LT's
+ Tremec 3550, D&D shifter, 3.73:1 gears, & TrueTrac differential
+ EVM watts & 3-link, Homemade LCA's, & Koni SA's
+ '00 Cobra R Brembos in front and SN95 Cobra rear brakes, R58 rims, & 275/40R17 Falkens
85GTVince is offline
post #5 of 12 Old 03-29-2009, 02:46 PM
Hipogt's Avatar
FWIW, I bought a Russell set for my 66 years ago. Could not install as the fronts were the wrong size on the caliper side. Never checked it out, but I believe the set was for drum brakes and their catalog only showed one listing for my application. Other than that, the quality seemed fine.
Rob
1995 Rio Red Cobra New project in the works.
1996 Cobra(4/09)- (4/12/13) The ESP adventure ends...
Armco at NJMP's Thunderbolt turned 'er into a parts car...
Hipogt is offline
post #6 of 12 Old 03-29-2009, 04:49 PM
I have russels on my cobra set up with no probelms. They are very nicely made.
93gt vert 5 lug-cobra brakes steeda/mm susp. 306 tfs tw trk heats steeda 18 cam gt40-3550
foxbody302 is offline
post #7 of 12 Old 03-29-2009, 08:10 PM Thread Starter
Flyin5-o's Avatar
--Vince
Yes I am aware that neither of the kits fit a stock '85. I have '87-'93 5.0 front spindles and an 8.8 rear.
Flyin5-o is offline
post #8 of 12 Old 03-29-2009, 11:54 PM
MileHi5.0's Avatar
I've got a set of Russels for my '89. I will be finally putting some new pads on the car after 20 years (I'm the original owner) and I figured I should put a better line on the car and this is what was recommended to me. I think you'll probably be ok with the Russels on your car.
Original Owner 1989 Mustang GT
1998 SVT Cobra. Black on Black and still all stock.
2006 GT in Legend Lime.........got some STUFF on it!
2014 Sterling Gray Mustang GT with Track Pack & Recaro's
MileHi5.0 is offline
post #9 of 12 Old 04-01-2009, 04:42 PM
Trader Feedback: (26)
I have the MM stainless brake lines and i absolutely love them. They are very well made. I haven't ever tried the Russel lines so I can't compare. I was deciding between the same two choices also and chose the MM pieces. I can't remember why.
Mark Thompson PSCA Mustang Maddness 37
84 Mustang GT, 408 super Vic intake, high port heads, pro system 1000cfm carb, inductions solutions sledge hammer nitrous system, glide. Full TeamZ suspension.
FordFreak300 is offline
post #10 of 12 Old 04-01-2009, 04:51 PM
Deeds's Avatar
I have used Goodridge in the past with good results.
Deeds is offline
post #11 of 12 Old 04-01-2009, 05:01 PM
TrickVert's Avatar
Trader Feedback: (28)
I have Russel lines up front (bought from a fellow Corraller), and ones from Classic Tube on the rears. CT's are DOT certified, if this matters to you, and CT was VERY helpful in the transaction.
Andy
'95 GT Vert - Rio Red - Grey Leather - Black Top
TrickVert is offline
post #12 of 12 Old 04-02-2009, 10:30 PM
poorracerkid's Avatar
I have the Russell lines and I've had nary a complaint about them.
All bleeding stops eventually.
poorracerkid is offline
**** '03 (Black) Cobra - Parting out *** 2003snake Modular Engine Parts 172 01-30-2010 10:49 PM
NEW COBRA, BULLITT, 10th & MACH 1 13" FRONT BRAKE KITS... STARTING @ $359.99!!! mustangparts Advertiser's Showcase 14 04-06-2009 01:00 PM
Maximum Motorsports SS brake lines Fox body with banjos ruger Suspension 3 04-05-2009 09:09 PM
Weird brake problem Rocket J General Mustang Tech 5 03-23-2009 09:00 AM
maximum motorsports stainless steel brake hoses and extras thirsty Suspension 4 03-12-2009 09:16 PM
