Pro-m with 4R70W, dashpot adjustments? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-15-2019, 01:03 PM Thread Starter
Is anybody running a Pro-M with an automatic trans? If so, did you have to make any adjustments to the dashpot values to keep the car idling well once put into gear?
I am assuming that there should be differences between an auto car and a 5spd car, but I am not too savvy on these settings just yet.
'01 GT:
YSI, 20lbs
89 LX:
347 stock
2001sleeper is offline
post #2 of 4 Old 06-15-2019, 03:32 PM
I run a 6R80 in my 98 Cobra using the Quick 6 controller. I didn't need to make any adjustments for idle after the install. The car stalled a few times while coming to a stop, but after driving it around a bit it's all but corrected itself.
Helomech74 is offline
post #3 of 4 Old 06-15-2019, 04:53 PM Thread Starter
that is good to know.
I have a Quick 4, but when I had the A9L on this new build (no specific auto tune) the car would die when putting it into gear.
Hopefully all goes well after I get the base idle set.
'01 GT:
YSI, 20lbs
89 LX:
347 stock
post #4 of 4 Old 06-16-2019, 01:47 AM
A9L2 / EFIDynoTuning
problem solved
DIY Tuning -
TMoss Porting - tmoss.efidynotuning.com
Decipha is offline
