94 95 Mustang Cobra 2.2 Kenne Bell flowzilla with bypass
Attaches to GT40 lower
Around 7000+ miles
Show 12 lb of boost under load
Comes with an extra pulley
hardware included
Car pulled hard (331,AFR 185, 42 Inj)
No heat issues/ No knock issues
Managed by Pro-M EFI
Supercharger is in 100% working order with zero issues. Supercharger is low maintenance and are straightforward to installing like if you were to be putting on an upper intake manifold that's it.. that simple. I have 6 Allen head bolts that are used to bolt SC to lower intake manifold. Also have two bolts that are used to secure the snout bracket to the coil bracket location. I was running a fox body style throttle body on my 94 cobra setup but I do have the elbow that is meant to you be used in 94-95 Mustang. I will include two additional pulley sizes. As in regards to boost reference it will vary. I was running 12 PSI but I was also running a GT crank pulley which is a 6.5 much larger than the cobras and that assisted in raising the Boost.
(SOLD)$2500 + the ride(SOLD)
Around 7000+ miles
hardware included
