Street car,couple of kits - Ford Mustang Forums : Corral.net Mustang Forum
 3Likes
  • 2 Post By JB Books
  • 1 Post By sradtodrag
post #1 of 16 Old 12-27-2018, 05:42 PM Thread Starter
2 small kits
The retards, progressor,ignition box,etc.
Nitrous outlet stand alone with adjustable low pressure switch.
427 T56 3.90 2 kits
JB Books is online now
post #2 of 16 Old 12-27-2018, 08:13 PM
tony91723's Avatar
Thru a manual...nice. Must be fun.
tony91723 is offline
post #3 of 16 Old 12-31-2018, 03:59 PM Thread Starter
It's fun,can be a bit of a hand full,at times.
Mounting the bottle straight up,seems pretty effective. Pulled the first empty bottle out
yesterday,felt so light I had to weigh it. 15 lb. (empty is 14 lb)
427 T56 3.90 2 kits
post #4 of 16 Old 01-07-2019, 10:24 AM
boostdcoupe's Avatar
Trader Feedback: (30)
nice! old school T handle FTW!
replaced the 93'ish coupe with a 76 F100, 393, 11.5:1, TEA CNC 205 TW's, custom Hyd Roller, Super Vic, 830 HP, AOD, Edge custom conv., Silverfox SPT-MAC-TB.
boostdcoupe is offline
post #5 of 16 Old 01-07-2019, 04:04 PM Thread Starter
I chose to remove the ball,and swap in the T handle,to activate the 2nd kit.
I was a little unsure about that move at first. Once I found the comfortable
angle,it was old school cool. LOL
boostdcoupe and boostup89 like this.
427 T56 3.90 2 kits
post #6 of 16 Old 02-01-2019, 01:33 PM Thread Starter
First update,the -4 T is gone,replaced with a 6/4/4 Y and 6 feet of -6 feed line.
Followed by a Nitrous Outlet,1/4 turn shutoff.
A 8'' length and NOS high flow filter.
And finally a 18'' length,2 hole adapter for pressure gauge and sender and -6 bottle nut.
427 T56 3.90 2 kits
post #7 of 16 Old 02-02-2019, 02:49 AM
Trader Feedback: (57)
Any track times or dyno numbers, also what size pills are you using?
1. Woman
2. Dyno
3. Dragstrip
sradtodrag is offline
post #8 of 16 Old 02-02-2019, 08:42 AM Thread Starter
No numbers. Right now (winter) .047n/.041f first kit,.048n/.042f second,-8 NGK's,pulling 7*.
AFR is 12.3-12.5 pump in the tank,110 in the stand alone.
427 T56 3.90 2 kits
post #9 of 16 Old 02-07-2019, 08:44 AM
Project Reef Blue's Avatar
Nice setup! Keep us posted!
Stock Block 408", TFS 11R 205, TFS EFI Carb R Intake, XFI 236HR, Tweecer, Faceplated TKO 500
10.49 @ 130mph
Project Reef Blue is offline
post #10 of 16 Old 02-28-2019, 05:51 PM
where is your line loc button ?
It's not the size of your shop, it's what comes out of it that counts.
mustangmatt8693 is offline
post #11 of 16 Old 02-28-2019, 06:04 PM
Trader Feedback: (21)
Love the T handle, it's what I used in my turbo 92 notch, with a toploader.
For everything that is worthwhile, there is a counterfeit.
boostup89 is offline
post #12 of 16 Old 02-28-2019, 06:51 PM Thread Starter
It's on the shifter,in this pic you can just get a glimpse of it.
The angle of the pic is misleading,that toggle is far away from the button.
427 T56 3.90 2 kits
post #13 of 16 Old 02-28-2019, 11:36 PM
My windsor is a hand full shifting the t56 but since its faceplated that makes it easier. I'm just running 1 kit and a 88 jet, Tq hit 869 on the dyno while tuning. The mcleod twin disk is holding up pretty good.
JB Books likes this.
1. Woman
2. Dyno
3. Dragstrip
post #14 of 16 Old 03-01-2019, 09:18 AM Thread Starter
Nice ! That's some serious torque. I looked back 5 years in this forum did not see a thread on it ?
With all the nitrous cars out there,not sure why this forum is so dead.
I will turn the car up a little in the spring with a Big shot plate (stainless/64 holes)
I use a Mcleod twin disc as well,so far so good.
427 T56 3.90 2 kits
post #15 of 16 Old 03-01-2019, 10:24 AM
5gearbanging's Avatar
I love the set up,
I got bit by the Nitrous bug last year just to settle a grudge race between friends with a little ZEX kit, Now I just want more!!
90 LX Notch 5.0 5spd, bolt on drag car with some giggle gas.
11.71 @ 116mph
86 Gt T-top 5.0 5spd, That one day project.
5gearbanging is offline
post #16 of 16 Old 03-14-2019, 07:34 PM
Ok now I see your line loc button. clean set up. I see the relays are you using a two stage relay set up ? Many years ago when I had a two stage set up on my 5 speed street car I used a two stage relay set up. they work great! first stage was actived by a full throttle switch on the carburetor and the second stage was actived by the cruise control "on-off" button on the steering wheel. with the two stage relays. if i wanted I could hold down the second stage button and when I hit full throttle it would go straight to the second stage, I found this very helpful when I was at the track and had slicks on the car. again your install looks great, and remember 3 pedals rule!
For Sale Aerospace Brake Kits and Components AutoFab Race Cars Suspension 13 04-08-2014 05:40 PM
For Sale SAVE up to $114 on Magnaflow! brothersperformance Advertiser's Showcase 0 06-16-2010 09:59 AM
GOTTA FAST FORD STREET CAR? jeff conley Drag Racing 0 05-08-2009 03:46 PM
Vengeance EFI Hot Street 2009 Class Rules!! [email protected] Drag Racing 0 01-05-2009 08:38 PM
