1995 mustang gt nitous set up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-28-2016, 01:21 PM Thread Starter
I've got a pretty much stock 5.0 Cai Long tube and bigger TB. I'm going to be running a zex 100 wet shot. My time now is 10 BTC and I want to know if that timing is okay to run or if I need to retard it more and what about colder plugs?
PorkchopSN95 is offline
post #2 of 5 Old 09-28-2016, 10:02 PM Thread Starter
Anyone?
post #3 of 5 Old 09-29-2016, 07:25 PM
FoxBodyNut's Avatar
ten degrees base isn't much advance. Typically, I'd say pull 2-4 degrees to be safe on a 100 shot. Having the timing at factory spec may mean you will be ok to leave it there. I believe I ran 14 degrees base on my old fox and dropped it to 8 or 10 degrees for a 150 shot. It has been so long, I can barely remember the little details. Sorry I'm not much help.
Yes, get a colder plug. One step colder should be fine.
94 Vert. 359w. AFR Renegade 185, FTI open track grind,(manifold swap in progress), Accufab 80mm TB. MM suspension. Baer/Cobra brakes. QuickTime Bell & T5-Z. Fox Longtubes, custom side-exit exhaust.
FoxBodyNut is offline
post #4 of 5 Old 10-01-2016, 12:49 PM
CallawayVW's Avatar
Trader Feedback: (27)
On 175hp dry shot, I ran 6* with spout out when setting it and 1 step colder plug. Of course this is a stone stock 5.0 engine so with aluminum heads you can get away with more timing. I also ran a little race fuel like 2 gallons to 5 gallons of regular 91oct fuel just to be safe.
But I agree with 150hp shot 8* should suffice especially if you have better than 91 octane fuel.
CallawayVW is offline
post #5 of 5 Old 10-02-2016, 03:04 PM Thread Starter
Thanks for the info!
For Sale Must Go 1995 Mustang GT JohnHenke Mustangs For Sale/Wanted, 1994-1998 39 04-12-2014 11:26 PM
For Sale 1995 mustang gt 347 stroker kid5.0 Mustangs For Sale/Wanted, 1994-1998 2 04-18-2012 07:10 PM
For Sale 1995 Mustang GT - Near Show-Car Condition MLC Stang Mustangs For Sale/Wanted, 1994-1998 0 04-07-2011 01:26 PM
For Sale 1995 Mustang GT wiring harness for ECM, 1995 GT auto ECM, 1995 GT low mile fan cantbuytime Miscellaneous Mustang Parts 0 01-06-2011 10:52 AM
