302 build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 11-29-2017, 09:49 AM Thread Starter
302 build
Hi there. I'm new to these forums.
Working on a 94 gt 5.0 build and had a question. I made a post yesterday but it said it had to be approved by an admin and still hasn't shown up so not sure if I did it right.
Question is:
302 is at the machine shop. Full rebuild and punched out .030 over. They zero decked the block (.030" off) and are milling the heads .012" (holly systemax 2.02's, 63cc down to 61cc combustion chambers). That's a total of .042" total cut. Are we going to run into any intake manifold alignment problems? Would elongating the holes and using a thicker bead of RTV front and back be a viable solution if it is mismatched? Or does the intake sides need to be milled for proper fitment?
The engine builder says there shouldn't be a problem. In my research online I've found different answers so I figured I ask here...
Thanks in advance!
GTO44 is offline
post #2 of 12 Old 11-29-2017, 10:14 AM
AtomicCoupe's Avatar
I would say if you trust the engine builder to machine and build your engine, then trust in his work. Express to him your concerns and let him do his job. If he knows what heís doing (and I hope he does considering you hired him) youíll be all set.
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is online now
post #3 of 12 Old 11-29-2017, 11:05 AM Thread Starter
I agree. I was just seeing if anyone had any personal experience with cutting the block and heads at the same time and how thier intake manifold fit after.
GTO44 is offline
post #4 of 12 Old 11-29-2017, 11:11 AM
Gotcha, I donít blame you at all. If anything youíll learn more about it.
post #5 of 12 Old 11-29-2017, 06:39 PM Thread Starter
Quick question, sometimes when I make a post it says it needs to be approved be an admin and nothing happens. Am I doing something wrong?
GTO44 is offline
post #6 of 12 Old 11-29-2017, 07:12 PM
There is no telling if it will need to be altered, unless he is assembling the engine he wont know either. The guy putting it together will be the one that will know
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is online now
post #7 of 12 Old 11-29-2017, 07:26 PM
Question is:
Thanks in advance!
Your machinist should know how to make it work. Either memory or a chart like this one.
If he mills your intake he doesn't know what he's doing. The intake side of the head should be milled .001 for every .0045 taken off the block or head mating surface.
Jay72 is offline
post #8 of 12 Old 11-29-2017, 09:44 PM
What I in situations like this is assemble the long block. INSTALL GASKETS to the intake with small daubs of silicone then sealer the side real well on the head side . Install intake using some studs as guides torque down the intake let it sit until glue hardens then remove intake. Then remove intake see if there is a mismatch. Or do the opposite couple daubs to the head and glue to intake side. Then you can see if there is a mismatch.
turbo2256b is offline
post #9 of 12 Old 11-30-2017, 09:04 AM Thread Starter
Thanks for the info! As you said the .001 for every .0045 makes sense for sure. But why does the chart say .01 for every .045? Cool thing is I thought I was going to lose 2cc's with .012" off the heads. According to the chart it will be closer 3cc. We'll take every bit of compression we can get
Great idea! We had planned on cutting the hold manifold bolts and using them as studs. What kind of sealer/glue do you use?
GTO44 is offline
post #10 of 12 Old 11-30-2017, 10:26 AM
My mistake on saying .001, it is .01
You also said .045 when it's .0045
Good thing we're not machinists
I've been using the same shop all my life, when I say I want .xxx taken off I just ask 'you'll do the intake side too right?'
And it all comes out perfect.
Jay72 is offline
post #11 of 12 Old 11-30-2017, 10:32 AM
Have used hitack, Indian head. Just something so just the daubs of silicon comes loose with out it pulling the other side off. You can then decide whether to match the ports or machine the intake.
post #12 of 12 Old 12-04-2017, 05:04 PM Thread Starter
Picked up the motor today. Looks great. They even painted it.
He said put the intake and heads on and if it's a mismatch he said he would machine the intake or heads depending on fitment.
Also said to use 10w-30 for break in, which consists on 3 or 4 warming up / cooling down periods. Then use 20w-50 after that. Also pointed out that we need to bleed the lifters. We had them soaking in oil the day we bought them. He said having them pumped up will effect the preload. Makes sense even though I've read opposite on different forums.
Another thing I noticed is it looks like he used the older style flat top pistons without the recess in the middle like the ones that came in the '94 302 motor. The piston says "P 1501 .030" and under that is says "02116 2". Looks like we'll pick up a little compression with those flat tops so cool lol. Anyone know the cc size of the valve relief's on these pistons?
GTO44 is offline
1994 Mustang Budget 302 Build BrettNorton Member Build-Up Projects 47 04-11-2015 11:36 PM
stockish cheap 302 build question mtw002 5.0/5.8 Engine Tech 5 02-02-2015 07:15 AM
keep building boosted stock block 302 or build oem block 408 ...street use killer5-0 General Mustang Tech 15 10-30-2014 10:59 AM
Stock bottom end 302 build questions. f150inline 5.0/5.8 Engine Tech 4 05-29-2014 01:05 PM
gunna build my first 302 purpleferrari 5.0/5.8 Engine Tech 17 02-23-2013 09:23 AM
