For Sale 4.6 DOHC Billet Secondary Tensioners & Extreme Heavy Duty (XHD) Chains - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-16-2018, 12:32 PM Thread Starter
authorized corral.net advertisers
Mod Mustang Racing's Avatar
Trader Feedback: (59)
It has long been known that the factory passenger side secondary tensioners on ALL DOHC's tension the chain on the wrong side, this creates cam timing errors as great as 7 degrees (regardless of how the cams are degreed!) This new kit from MMR brings the margin of error down to a mere 1 degree. Properly tensioning the chain and adding the heavy duty chains allows you to degree the cams perfect every time and testing has shown 4-5MPH gains in the 1/4 mile! Get your timing under control with this kit today- a must for any High HP application!! As used by team MMR to produce 3000HP and 10,000rpm. The driver tensioner from the factory leaks between the cylinder head and tensioner, reducing oil to the camshafts and cylinder heads which cam create timiing variances and broken secondary chains. A must for all applications with aftermarket valve springs AND / OR cams. Also fits 2007-2014 GT500. Anodized for corrosion resistance.
*Plug and Play Install
*Fully rebuildable with replaceable wear strips
Fits:
*96-04 Cobra
*2007-2014 GT500
*5.4 DOHC Navigator
*03-04 Mach One
*All Australian 4.6/5.4 DOHC Applications
Includes:
*Billet Secondary tensioners (driver & passenger side) PN# 444036 & PN#444038
*UPGRADED XHD (Extreme Heavy Duty) SECONDARY chains pr. PN#487028
*ARP Hardware
Order now: MMR 4V / DOHC BILLET Secondary Tensioners & XHD chain kit [444032] - $599.99 : Modular Motorsports, Home of the Worlds Fastest Modular Engines
1-877-MOD-POWR
Precision Engineered Modular Engines and Components,
,5 speed Record [email protected]
RANKED TOP TEN MUSTANGS OF 2011 by MM&FF Magazine
Mod Mustang Racing is offline
post #2 of 8 Old 04-16-2018, 02:19 PM
Sent you guys a PM few weeks ago.
Twin Turbo 03 Cobra
Russ ZTT is offline
post #3 of 8 Old 04-19-2018, 01:33 PM Thread Starter
We are rarely online on the forums, a call to our staff will get you the fastest answers to your questions. We will take a look and see if we can answer your question now...
1-877-MOD-POWR
post #4 of 8 Old 07-05-2018, 01:26 PM Thread Starter
1-877-MOD-POWR
post #5 of 8 Old 09-04-2018, 12:32 PM Thread Starter
1-877-MOD-POWR
post #6 of 8 Old 12-03-2018, 01:34 PM Thread Starter
1-877-MOD-POWR
post #7 of 8 Old 02-18-2019, 11:43 AM Thread Starter
1-877-MOD-POWR
post #8 of 8 Old 04-10-2019, 11:42 AM Thread Starter
1-877-MOD-POWR
Billet Secondary tensioners finally done -no more cam timing errors- come in and see> Mod Mustang Racing Modular Engine Parts 67 01-11-2018 01:37 PM
For Sale Billet Secondary Hydraulic Tensioners for all 4V 4.6/5.4 - no more cam timing errors Mod Mustang Racing Modular Engine Parts 7 12-07-2015 01:24 PM
For Sale Updated Heavy Duty Secondary Tensioner and chain kit for all DOHC applications Mod Mustang Racing Modular Engine Parts 7 01-13-2014 12:56 PM
For Sale 4.6 parts: billet oil pump, chains, cover BlownGT88' Modular Engine Parts 12 01-15-2012 01:13 PM
Billet Secondary tensioners finally done -no more cam timing errors- come in and see> Mod Mustang Racing Modular Mustang Racing 28 08-31-2011 04:19 PM
