For Sale 96-98 4.6 DOHC engine parts TONS and more.... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 01-14-2018, 10:36 AM Thread Starter
Jeepman1's Avatar
Trader Feedback: (99)
Parted out 96 cobra engine, ported heads, Cloyes Hex a just gears and timing set, texsid Block, has 6 bolt crank no issues
Texsid Blocks 350.00 have 2 here ...
also have 2 WAP blocks 250.00 each
6 bolt cast Crank 100.00
8 bolt cast crank 125.00
Ported B Heads and cams 500.00 a set
stock B heads and cams 250.00 a set
Timing cover with tensioner and idler 100.00
COP valve covers 100.00
T stat housing and hoses 80.00
Heater core hoses 35.00 each
Cobra intake 350.00
Accufab Throttle Body 225.00
Oil pan 35.00
Oil cooler 125.00
IMRC deletes 60.00
Alternator 40.00
Alt bracket 25.00
Coolant crossover 75.00
24lb injectors 75.00
Fuel rail 75.00’exhaust manifolds 80.00
Msd wires 40.00
Energy suspension engine mounts 75.00
6 bolt flywheel almost new 40.00
Clutch almost new 40.00
Starter 30.00
T45 trans harness 40.00
99-01 Cobra Intake 350.00
03-04 Mach1 intake 275.00
more here in bins, accessories, pulleys, timing covers, valve covers, B heads.. tensioners, hoses, you name it I may have it...
Tons of parts here just ask..will ship
03 Cobra Redfire 630rwhp
Jeepman1 is offline
post #2 of 8 Old 01-18-2018, 02:07 PM
I'll take the imrc deletes. What clutch are you selling?
Sent from my SM-N950U using Tapatalk
rosco55 is offline
post #3 of 8 Old 01-20-2018, 01:39 AM
MVK13's Avatar
Trader Feedback: (28)
Pm me price on alt & poly motor mounts to 85286 please?
Sent from my VS996 using Tapatalk
98 Vert: C Heads, Teksid, Coyote crank=4.75L, Manley rods, Custom DSS Pistons (11:1), 98 Intake cams, 01 Cobra intake+1/2" spacer, On3 FF+MP 70mm .63 AR, Snow Stage 2, J&S Vampire, Bilstein C/O fronts, UPR K W/MM Arms, 04 Cobra Rack, 98 T45+Tri-ax, 04 IRS+MM+FTBR, 3.55 Yukon, 2000 R Brembos+factory rears, Goodridge lines, 18x9.5 '09 GT500s, 6pt MM Bar. Thanks: My Mustang Gal, my Boys, NASVT, The Car Guy/Chandler Automotive Machine Services in Chandler AZ and my Buds
MVK13 is offline
post #4 of 8 Old 01-20-2018, 04:53 PM
I will buy a set of IMRC Deletes if they would work with a 96 Cobra, shoot me a text! 484 Five 74 Seven 051
post #5 of 8 Old 01-20-2018, 10:12 PM
How much for the timing cover shipped to 17402?
Are the blocks bored out at all or stock sized cylinders?
Semper Fi To All Jarheads
Just Spray It!!!
SGT MERC is offline
post #6 of 8 Old 01-21-2018, 08:42 PM Thread Starter
Jeepman1's Avatar
Timing cover 125 shipped
blocks are standard bores
Jeepman1 is offline
post #7 of 8 Old 03-15-2018, 08:26 PM
Got any IMRC Deletes left?
1997CobraDHP is offline
post #8 of 8 Old 03-16-2018, 06:00 AM Thread Starter
Jeepman1's Avatar
none
Jeepman1 is offline
