I have a complete 1999 cobra engine that I am parting out. Engine has less then 8K. Will ship at buyer cost. All reasonable offers accepted.
Picture available upon request
email is kdrbond44@comcast.net
Located in Colorado Springs, CO
alternator
intake manifold with injectors, throttle body, and sensors
Cobra engine wiring harness
heads with rockers, and cams, and water passage tubes
(8) COP (will not separate)
Teskid block excellent condition except number 8 cylinder has scratches from Ford install a smaller piston then what was required.
Cobra Crank-excellent condition
timing cover
valve covers
water crossover tube
oil cooler
oil pan
exhaust manifolds-stock
egr tube
radiator hoses with thermostat housing
timing chains
harmonic balancer
All three Ford Factory service manuals for a 1999 mustang
Factory tools used to disassembly and assembly engine. (tools to set timing and remove and install rockers)
I have every nut and bolt that came with this engine, so if it's not listed that doesn't mean I don't have it.
Will also sell all together if someone wants it.
____________________________________
alternator
timing cover
valve covers
oil cooler
oil pan
egr tube
timing chains
harmonic balancer
