99 Coyote Swap / Hood Recommendations - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-11-2019, 07:22 PM Thread Starter
jamessr23's Avatar
I have a 99 New Edge that I am taking the 6 out of.
I want to put a Coyote in it. Any recommendations on hoods/cowl height? Don't want too tall for visibility.
This will be primarily a strip car. Thanks in advance!
jamessr23 is offline
post #2 of 3 Old 03-13-2019, 08:26 PM Thread Starter
jamessr23's Avatar
any feedback?
any feedback
post #3 of 3 Old 04-17-2019, 07:45 AM
First I think the reason no one responded is because you might have put the topic in the wrong area. Second, depending on the intake you could just use the stock piece, if you run the boss or cj intake then you might want to look at one with a cowl. It's completely up to how you want the end result to be.
Lx5.4 is offline
Coyote swap Fox vert milwkeesbest Member Build-Up Projects 170 08-24-2017 03:28 PM
sn95 Coyote swap tubular K member starter access BeanCrusher Member Build-Up Projects 1 04-01-2015 11:20 PM
For Sale 1994 coyote swap cobra jonboy688 Mustangs For Sale/Wanted, 1994-1998 9 04-19-2014 01:25 AM
Black 2011 hood scoop hood swap? vteckiller2000 S-197 Mustang GT (2011-2014) 6 04-26-2011 08:46 PM
Does anyone have access to the actual text contents of TSB's for 99 Cobra? lo pony GT & SOHC 1 03-02-2002 01:36 AM
