1992 LX LSX swap, wiring dilemma - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 12-30-2017, 07:51 PM Thread Starter
I removed the stock engine bay harness and moved my battery to the trunk. I have a few wiring questions.
I built my own harness using the stock harness and a BP automotive fuse block. Everything works as it should except I am lost on a few things..
1. Fuel pump wiring, my fuse block has a single gray wire from it to go to the fuel pump, I cannot figure out which wire this needs to be wired into in the floor harness that runs along driver side floor board.
2. I need a 12V ign and while cranking source
3. The car with the clutch pedal depressed will not crank, the car ran fine with the 5.0 in it before I tore it all apart.
Other than these issues I have about everything else covered as far as I can tell....
1991SSP is offline
post #2 of 3 Old 01-07-2018, 11:26 AM
Trader Feedback: (71)
1. See attachment
2. See attachment. You can also tap into it at the ignition switch.
3. Jump the clutch safety switch plug, that way you don't have to press the clutch pedal to start the car, I'm guessing you are going auto?
1986 Mustang GT Coyote swap project car
1991 Mustang GT LS1 HCI, C4, 3.90s, [email protected]
91foxbodygt is offline
post #3 of 3 Old 01-10-2018, 10:49 PM
stangklick's Avatar
No it looks he is manual not auto. While jump the nuteral switch if it runs when you crank then the ground side works you can test the switch with a voltmeter if you need to chk if need to replacement???
stangklick is offline
1993 LX Convertible "budget" 351W Swap marshal4bob Member Build-Up Projects 22 04-07-2015 10:38 PM
For Sale 10-second 1992 Mustang LX - Hatchback Charged97 Mustangs For Sale/Wanted, 1987-1993 3 02-11-2013 06:05 PM
1992 Twin Turbo LX Hatch Charged97 Mustangs For Sale/Wanted, 1987-1993 68 02-11-2013 04:56 PM
For Sale 1988 mustang lx with 5.0 5 speed swap parts speedracer89 Mustangs For Sale/Wanted, 1987-1993 4 10-25-2012 10:03 PM
Want To Buy 91 LX 5.0 dash and other wiring harnesses TJs98GT Electronics and Entertainment 2 11-06-2011 06:26 PM
