68 Firebird 428 with Ford EEC IV brains - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 07-10-2017, 09:21 PM Thread Starter
gator68428's Avatar
It all started with the Mass-FLO (now PRO-M) EFI system. Back in 2007 I bought the full system for my 1968 Pontiac 428. At that time the system had the EEC IV (computer) from the 89-93 A9L Fox Body 5.0. The system fired right up and worked decent.
Long story short, I bought a wideband and tuning hardware and learned how to modify and optimize the tune for my setup and got it running better under wot for full power. Now I know more about the Ford EEC than I ever thought I would. I still have the system in my Firebird with current setup in my signature. I do track days and AutoX mainly with the car including Optima USCA events.
You can see in my engine compartment pic: those are the Mustang style injectors (42 #/hr), that's the Mass-Flo 1000 cfm 4-barrel (carb style) throttle body, and original Mass-flo wiring harness and custom Mallory PIP distributor for Pontiac (spec'd by Mass-Flo). I custom made the cold air intake from scratch out of fiberglass and custom installed the 100mm MAF sensor (using Mass-flo's original supplied frequency to DC voltage converter--reprogrammed the MAF xfer function myself).
I currently use the quarterhorse and binary editor. I have been very active on EECtuning dot org. The system works great.
-Mitch
68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, Mass-Flo EFI with EEC IV, 100mm MAF, 42#, TKO600 5-speed, TCI Eng subframe and Torque arm rear susp, Ridetech coil overs, Kore3 C6 Z06 brake kit, C6 dual mode mufflers
Roebling Road Raceway, NASA HPDE https://youtu.be/DPp1l9-FuNE
gator68428 is offline
Junkyard Horsepower SUMMARY! slo5oh 5.0/5.8 Engine Tech 231 01-30-2015 11:35 PM
For Sale Ford Man Cave Decor,mugs and a few shirts zuritausmc Miscellaneous Mustang Parts 28 01-17-2013 01:14 PM
Taylor 409 race wires black part number 98065 5.0 gt dreamer Electronics and Entertainment 28 09-07-2012 05:41 PM
