8.8 strength? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 01-28-2016, 03:44 PM Thread Starter
panic's Avatar
8.8 strength?
1985 notch with turbo LS & 4L80E, 8.8.
What's needed to keep the 8.8 alive?
Who mods 8.8 on Long Island?
Thanks.
panic is offline
post #2 of 8 Old 01-28-2016, 03:59 PM
87warrior917's Avatar
Get the tubes welded, 9" ends, strange axles, and there's couple girdle designs you can do to add more rigidity.
1990 lx notch: 306, AFR 185, TFS 1 cam, Holley Systemax, 75mm tb, 80mm Pro-flow MAF, 24lb injectors, Homemade 4" powerpipe, MSD 6al-2 step, Bassani LT & X pipe, Flowmaster 44 & 3" tails, 3.73, 5 speed-Pro-5.0: [email protected] 60ft 1.51 best to date
87warrior917 is offline
post #3 of 8 Old 01-28-2016, 04:02 PM Thread Starter
panic's Avatar
Thanks.
I was concerned about the small 2-3/4" tube diameter, and 28 spline count?
All the Ford 8.8 with bigger Ranger, Explorer and 150 3-1/4" tubes and 31 spline need grafting to add the U & L control brackets, and also not sure if the width is OK?
panic is offline
post #4 of 8 Old 01-28-2016, 04:14 PM
Grand Marquis and Crown Vics rear ends are 3" tubes. They are too wide but if you go with all the mods mentioned its not all that differance in price.
turbo2256b is offline
post #5 of 8 Old 01-28-2016, 04:21 PM Thread Starter
panic's Avatar
Does someone sells the Mustang brackets, or a jig to attach them correctly?
panic is offline
post #6 of 8 Old 01-28-2016, 07:19 PM
mIGHT TRY Moser
Myself would rather spend the money on a 9"
post #7 of 8 Old 01-29-2016, 04:19 PM Thread Starter
panic's Avatar
I agree that a 9" would work well, but the higher internal power loss and more weight don't help. I'm pretty sure I won't need to change ratios with any frequency, so the "drop out" feature has no value.
I'd buy an 8.8 already assembled but can't find any with the features I want.
Everyone will make me one for $3,500 -no, thanks, it's not pro stock.
panic is offline
post #8 of 8 Old 02-07-2016, 09:22 PM
racin lsc's Avatar
Trader Feedback: (40)
just do a Mustang 8.8, why do something else as they haven proven themselves on many fast cars. Just do as stated above, 31 spline axles, 9" ends, 31 posi or spool and girdle cover.
93 Coupe, Reef Blue, a/c, 3:55's, 10 holes,
1/8 6.56 @ 103.23 mph, 1/4 10.37 @ 128.49 mph 1.43 6/06/15
1/8 Nos 6.06 @ 114.71 mph 1.38 12/16/15
1/4 Nos 9.879 @ 135.29 mph 1.39 12/19/15
racin lsc is offline
My Fox body 8.8 build with pics, check it out... FiveLiterFox General Mustang Tech 129 09-10-2018 03:44 PM
For Sale T-5,clutch,cable kit,gears,rearend,flywheel and more nasty 91 Drivetrain Parts 16 08-21-2016 08:45 AM
For Sale 8.8 companion flange, 2.73s, axles, diff cover, shock brackets nobody special Drivetrain Parts 1 07-18-2014 02:19 PM
4.88 and 5.13 gears in 8.8 rear - any strength issues tbird50 Drag Racing 4 12-04-2013 08:39 AM
For Sale Rebuild you 8.8 T/A Girdle / 3.73 FR gears & MORE! 89StrokerStang Drivetrain Parts 9 07-14-2011 07:53 PM
