2002 mustang gt th400/junkyard 5.3 build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-29-2015, 10:14 PM Thread Starter
So I changed my mind on the l92 swap. I picked up a th400 from a 73 corvette today for 150.00 $$$ "good deal in my book" I have a 5.3 iron block vortech engine out of a 2004 Chevy Tahoe with 70k miles on it. The plan is too pull the engine apart, all new bearings,gaskets,seals,arp rod bolts,arp head studs, some head porting, a crane 224/232 hr, comp double spring upgrade. I wanna run a square bore carb intake with a Holley stand alone self tuning efi. That coupled with a big plate kit on top (250hp shot). What parts do I need too bolt the th400 up too the 5.3, what do I need too make the 5.3 work in the stang? What stall should I look for? Gearing for 1/4 mile only?this is a completely gutted drag car. I'm hoping the engine holds up for awhile but I have access too over a dozen of these engines at the drop of a hat and already have two spares sitting in my shop. Also a driveshaft too go from the 8.8 too the th400 as well as braking. Also running lexan windows, and the absolute lightest of everything. I want a race weight of around 2900 and around 700rwhp. All my money for the build is going to the chassis and suspension itself. Any insight or ideas are greatly appreciated!!
1999 mustang gt,Fully forged shortblock,Patriot cncd heads,Comp 270 cams,60# injectors,Bbk 315 lph pump,jms fuel max v2,Novi 2000 with Paxton a2a intercooler,3.25 upper,Innovator west 15% crank pulley,T-45 with spec stage 3 clutch,3.73 gears
Dennis5374 is offline
post #2 of 2 Old 11-07-2015, 11:34 AM
stangonlaughngas's Avatar
You need a crank shaft spacer to bolt up your trans to the 5.3. Buy a tubular kmember/mounts from AJE and the motor will drop in .
stangonlaughngas is offline
1995 Mustang GT 5.0 Build mechanic_tyler93 5.0/5.8 Engine Tech 13 09-10-2014 09:51 AM
For Sale Misc fox body parts n8secstangg Miscellaneous Mustang Parts 12 02-24-2013 12:29 AM
Want To Trade 2002 Mustang GT 50k miles Stroked410 Mustangs For Sale/Wanted, 1999-2004 1 03-10-2012 03:57 PM
For Sale 2002 Mustang GT rrg9550 Mustangs For Sale/Wanted, 1999-2004 19 07-23-2011 05:44 AM
