03 Cobra LSx - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 40 Old 12-30-2014, 07:58 PM Thread Starter
03 Cobra LSx
This isn't my first LS swap but it will be my longest and most extensive build.
The car is a true 50k mile 2003 Redfire Cobra with full suspension and some other goodies. That includes a SRA conversion as well. Suspension and fuel system are built to handle 4-digit power.
It will be awhile before I'm testing those limits, if at all.
Plans- A sort of "what the terminator could have been"
Positive displacement blower, like to make 600-650 reliable horsepower.
Full street car, meaning-
AC, power brakes, power steering etc are a MUST
6 speed transmission (no one likes to cruise an auto)
Capable of distance driving (LSFest is about 3.5 hours from here and I like to make the drive every year, this car has to be able to make that. Shouldn't be a problem reliability wise)
So far I've purchased an 01 ls1/t56 lower mileage dropout that will get the car on its feet. Should be here in the next couple days.
AJE parts will make sure it drops right in and should be just a matter of plumbing the clutch hydraulics and locating the shifter correctly (more on that in a bit)
I'll also be using Holley EFI, as I used it on my last build. Can't say enough good things about it so they'll be getting my money again.
Ive got a full stainless exhaust and Kooks
1 7/8" longtubes that will be going on as well.
Power steering has been redone already and I'm in the middle of deciding how I'll tackle the AC system.
I will probably go ahead and swap the cam with a Tick grind while the motors out on a stand just for simplicity. Nice part of a PD blower is the cam will work well NA for the time being. (At 7k, the blower is going to have to wait til the dust settles on the rest of my spending)
Rear end is good to go and has boost friendly 3.55s and a nice locker.
Also have a meth tank and lines already plumbed and installed for eventual boost.
Obviously the stock clutch and other weak parts aren't going to last very long so they may slow me up a bit as I collect those parts as well. Lots of odds and ends I'm probably forgetting but you can get the idea.
Progress will be a little slow at first. Just going to get the car up and running and lined out as close to the way it would have been from the factory. Reliable street-ability remaining priority number one.
On a side note, when I bought the car it came on a set of draglites
I've seen worse wheels on a cobra, but not many.
So I bought a set of 18x9/10 FR500s to replace them.
Just ordered the Toyos today so who knows when they'll actually make their way on the car.
Tannerc91gt is offline
post #2 of 40 Old 12-30-2014, 09:13 PM
racin lsc's Avatar
Trader Feedback: (40)
nice car
93 Coupe, Reef Blue, a/c, 3:55's, 10 holes,
1/8 6.56 @ 103.23 mph, 1/4 10.37 @ 128.49 mph 1.43 6/06/15
1/8 Nos 6.06 @ 114.71 mph 1.38 12/16/15
1/4 Nos 9.879 @ 135.29 mph 1.39 12/19/15
racin lsc is offline
post #3 of 40 Old 01-11-2015, 09:53 AM
I made a bracket for my 99 cobra lq4 swap that bolts to the ls block and allows the ford A/C to bolt to it. I didn't have to crack the a/c line open or anything. I will be reproducing this bracket if you are interested. I'm also doing the same type of bracket for the ford p/s pump.
tvanlant is offline
post #4 of 40 Old 01-11-2015, 06:05 PM
racin lsc's Avatar
I already have a/c and had p/s but went to manual now, but still have my a/c. I used all the LS1 stuff.
post #5 of 40 Old 01-13-2015, 05:40 PM Thread Starter
PM'd you Tvalant.
I've got all the Chevy components to build an AC system but would prefer using the ford compressor.
Bought some 317 heads, picking up my drivetrain tomorrow. Holley efi system will be here tmrw as well. Talked to Martin at tick and picked out a cam. Shooting for 600-650rwhp when it's all said and "done".
post #6 of 40 Old 01-14-2015, 11:44 PM Thread Starter
post #7 of 40 Old 01-18-2015, 03:42 PM
botlrokit93's Avatar
Trader Feedback: (26)
Looking good!
AARON
_______
botlrokit93 is offline
post #8 of 40 Old 02-09-2015, 01:11 AM Thread Starter
Went ahead and pulled the motor back out for some upgrades.
Now has milled 243s, a tick cam package, and a FAST 92/92
As of now the motor and transmission are in the car and I've begun the wiring
post #9 of 40 Old 02-09-2015, 01:15 AM Thread Starter
post #10 of 40 Old 02-09-2015, 06:59 AM
What ECU are you running?
AARON
_______
post #11 of 40 Old 02-09-2015, 07:46 AM Thread Starter
Holley EFI
post #12 of 40 Old 02-09-2015, 02:28 PM
TopNotchLSX's Avatar
Have you figured out what you will do with the Ford fuel pump driver module and the constant control relay? I am doing this swap on an 02 and will likely delete both and simply use a relay if possible.
Built Ford tough with all kinds of stuff!
TopNotchLSX is offline
post #13 of 40 Old 02-09-2015, 08:37 PM
Originally Posted by Tannerc91gt View Post
Holley EFI
Good choice. I used the Holley on my LS swap in my '01 GT, and was blown away by how it started immediately and was able to be driven within minutes. Good luck with the build, it looks great.
AARON
_______
post #14 of 40 Old 02-09-2015, 09:48 PM Thread Starter
Holley EFI
I used it on my 98 swap and loved it. Worth every penny, wasn't going to pass up the chance to use it again
post #15 of 40 Old 02-12-2015, 09:40 PM Thread Starter
Well the fast just doesn't work. Neither does the Fbody radiator. Fixing one issue just has a domino effect through the rest of the engine bay. Im going to look into relocating the expansion tank otherwise I think I'll be selling the fast and trying something different. Will allow me to use the factory Ford radiator, fans and a lot of the associated components.
Tried out a Vic Jr and elbow today, clears up every fitment issue and I don't hate the way it looks like I thought.
Have a couple options I'm still looking at, and a large summit order that is either missing parts or contains the wrong parts. So it's all gotta go back.
But hey, they gave me a hat so I guess all is forgiven.
Routed the rest of the fuel system, finished the charging harness, and rounded up the rest of my sensors. At least I made some sort of progress.
Going to have to make my own shifter as it hits the console on 2,4,6 shifts.
post #16 of 40 Old 03-02-2015, 02:33 PM Thread Starter
Car is going turbo now.
post #17 of 40 Old 03-03-2015, 02:14 AM
GMundertaker's Avatar
Trader Feedback: (72)
Trans
Did it have a 4R70W swap? I see it had an auto shifter in it. I am planning a future swap so I'd be interested in associated parts. I have none to date.
thanks,
Matt
03' Terminator Cobra Coupe #920 MG
GMundertaker is offline
post #18 of 40 Old 03-29-2015, 01:46 PM Thread Starter
put the motor together and sat it in the car. Hung my turbo and downpipe as well
post #19 of 40 Old 04-02-2015, 05:51 PM
The main question I have is why hack up a low mileage clean Cobra?
'01 GT - sold
'05 CVPI - DD
'00 GT - Broken
Gravik is offline
post #20 of 40 Old 04-02-2015, 06:08 PM
-Wraith-'s Avatar
Trader Feedback: (29)
I'm sure he bought it as a roller without motor and trans hence going the cheaper route of the lsx. Otherwise it's a pointless swap since the 4v cobra motor could handle/make more power than an ls1 can.. a lot more.
Just another slow mustang with a single turbo....
-Wraith- is offline
post #21 of 40 Old 04-02-2015, 07:50 PM
Terminator deserves to be ALL FORD!
If you can't hear it before you see it; what's the point?
1MeanNonPI2v is offline
post #22 of 40 Old 04-02-2015, 11:18 PM
LOL.....
AARON
_______
post #23 of 40 Old 04-03-2015, 10:00 PM
more pics and get busy love to se it up and running, looks like you could grab a triax sifter handle and it should fix your problem
aaron222 is offline
post #24 of 40 Old 04-03-2015, 10:16 PM
-Wraith-'s Avatar
LOL.....
What's funny about that?
-Wraith- is offline
post #25 of 40 Old 04-04-2015, 07:19 PM Thread Starter
Bought it as a roller, like it says.
Don't care what the die-hards thinks, I don't owe Ford any more than they owe me. So it's wasted breath. Haven't "hacked up" anything. Plenty of people have wrapped these things around trees, I think it'll be ok if one of them remains extremely well cared for and garage kept.
Finished building the 5.3, hotside is in. Lower core support and front bumper will be tubular to clear up some space. Then I'll hang the intercooler and radiator this week.
post #26 of 40 Old 04-04-2015, 07:45 PM
Definitely not a hack job, the packaging looks good. BTW, I like the black Hi Ram. I have one as well and often wondered how it would look black. As soon as time allows im yanking mine off and having it powdered. Keep up the good work, and keep us posted.
AARON
_______
post #27 of 40 Old 04-05-2015, 09:22 AM
racin lsc's Avatar
coming along great!
post #28 of 40 Old 04-06-2015, 10:00 PM Thread Starter
Looks and feels like a mess right now but it's progress of sorts
Cut out the lower core support
New tubular support will be here tmrw as well as a front bumper
Intercooler showed up
Started working on the coldside. It's not gonna work right out of the box but with a different chassis and an aftermarket Intake it was expected. Kind of stuck for now until I get the radiator mounted and the supports in.
post #29 of 40 Old 04-07-2015, 09:34 AM
Which intercooler is that?
AARON
_______
post #30 of 40 Old 04-07-2015, 04:36 PM Thread Starter
Bumper support and lower core support came in. Looking like they'll do the trick
post #31 of 40 Old 04-07-2015, 11:03 PM Thread Starter
Ended up going back to the garage and getting some more done.
Built a mounting bracket for my intercooler
Started mocking up my coldside piping.
Going to have to do some more cutting and moving but things are getting close. I knew the coldside would need some revision but it's gonna work great
Looking good. You can tell from the headlights how humid it's been the last few days.
post #32 of 40 Old 04-09-2015, 03:34 PM
Wow. Killer build. Coming from a guy that cut up a 1995 cobra with 30k on the clock that was 100% factory original... don't worry about the purists. Keep up the good work.
kbscobravert is offline
post #33 of 40 Old 04-09-2015, 03:42 PM
racin lsc's Avatar
Just ordered my cam from Martin at Tick, that guy sure knows his stuff. I went with a solid roller this time.
post #34 of 40 Old 04-09-2015, 05:10 PM Thread Starter
Originally Posted by racin lsc View Post
Just ordered my cam from Martin at Tick, that guy sure knows his stuff. I went with a solid roller this time. ]
I ended up canceling the Tick turbo cam and goin with an LJMS grind. Martin does know his stuff but their customer service has been lacking with the last few times I've tried to do business with them. Regardless, you made a good choice
post #35 of 40 Old 04-21-2015, 04:05 PM
2Guard's Avatar
Where did you get the Bumper support and lower core support from?????
Car/92 5.0/ Engine stock block/ and bolt-ons.. [email protected] (sold)
97 Cobra All stock for now...
2Guard is offline
For Sale HUGE COBRA PART OUT INTERIOR/EXTERIOR B MOTOR C MOTOR TONS OF STUFF CHEAP! vettez062002 Modular Engine Parts 204 01-21-2016 01:25 PM
For Sale (IN) 1989 GT Supercharged, 03 Cobra Disc Brakes, Low Miles, Original Paint Shanenindy Mustangs For Sale/Wanted, 1987-1993 32 12-13-2014 07:56 PM
1994 - 95 Cobra grille: pony or snake? 1oldfox 94/95 Tech 57 04-19-2013 11:53 PM
For Sale BONDURANT COBRA VIC slidejob Other Fords and Trades 0 12-06-2011 11:49 PM
