5.3 or Coyote Swap? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-09-2014, 03:35 PM Thread Starter
5.3 or Coyote Swap?
I was originally going to do a 5.3 turbo swap into my 87 foxbody. But now I came across and actually bought a coyote out of a wrecked car. Got it with wiring harness and ecu. Now Im stuck between which one to put it.
Parts I have.
-Coyote
*Complete long block w/acc.
*OEM wiring harness w/ ECU
Chevy 5.3
*Long block w/ ls6 cam/manifold
*Standalone plug-n-play wiring harness
Still need k-member for whatever motor goes in.
As for turbo stuff ,I have a Turbonetics 76mm, and 40mm racegate, 80lb injectors, -8an fuel lines from tank to front with twin 255 pumps, intercooler and all the piping. Ill just need to fab up hot parts for whatever motor goes in.
What would you guys do? Car will be tuned on e85.
AR_Stang is offline
post #2 of 3 Old 10-09-2014, 04:27 PM
4eyedcoupe's Avatar
Trader Feedback: (36)
Both are good options. What's the cars purpose?
A few pro's for each off the top of my head.
5.3 has good power out of the box(especially with your current set up) and will be much cheaper to modify when it comes to upgrades in cams ect. The 5.3 will leave you with much more room to work with for the turbo set up than the Coyote. You could probably sell the coyote and cover most of the cost to do the entire build on the 5.3l. I would think the 5.3 is alot lighter than the coyote.
You won't get sh*t from anyone for a coyote swap. Good power out of the box, but expensive to upgrade. Coyote swap edges out the 5.3l in the "wow" factor, but both are becoming more and more common.
If I was building a race car, I'd probabaly go with the 5.3($ reasons). If I was building a show car I would go with the coyote(wow). Thats just me, everyone has thier own ideas and likings.
4eyedcoupe is offline
post #3 of 3 Old 10-10-2014, 06:37 PM
^ I agree
Tino is offline
For Sale kooks coyote swap headers larryb Exhaust Parts 2 10-26-2014 08:47 PM
Terminator vs coyote swap? fireman02 General Mustang Tech 20 09-06-2014 06:53 PM
Want To Buy Wtb :coyote swapped coupe or 93 cobra with swap richardv6 Mustangs For Sale/Wanted, 1987-1993 0 09-04-2014 10:15 PM
For Sale 1993 Lx Coupe Coyote swap Mint!!! 5.0 Bartman Mustangs For Sale/Wanted, 1987-1993 29 11-10-2011 11:02 PM
