1993 Mustang Notch LS1 Project - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 26 Old 06-17-2011, 01:11 PM Thread Starter
I bought this 1993 mustang notch a few weeks ago, I had two 5.0's in high school and just missed how small and how they handled... since the 5.0's i had a few other cars one of which i still owe 2001 camaro ss. I love the power of the GM LS1 motor's which is why I am going to do this project. Light weight of the fox + the power of the ls1 = ass raping! This will be a slow working project because i plan on buying everything before i take into the fox. Goal is to get a 10 sec pass!
Here is my Bone stock 4 banger
Driving her home
NotchLS1 is offline
post #2 of 26 Old 06-17-2011, 01:12 PM Thread Starter
NotchLS1 is offline
post #3 of 26 Old 06-17-2011, 01:14 PM Thread Starter
Huge parts list
LS1 short block Have
LS1 front engine cover Have
LS1 rear engine cover Have
Ls1 valley cover
Ls1 knock sensors Have
UnderDrive Pulley Have
Crank Bolt Have
Timing Chain
Water Pump
Oil Pump
Oil Pan Have
LS7 Lifters
Ls1 lifter trays Have
Intake manifold
Throttle body
Fuel rails
Fuel rail covers Have
Injectors
Cam
Heads
Head gaskets
upgrade oil pump,push rods, springs
Wiring harness Computer
Cluster
Headers
X Pipe
Cut outs
Mufflers
Tail pipes
Steering shaft
Fittings for Fox's power steering pump
K-Member
A-arms
Spindles
Aerospace drag brakes front
Line lock
Struts/shocks
Springs
Wheels
Tires
TH400
Trans cross member
Sub Frame Connectors Have
Drive Shaft
8.8 Rear end Have
Gears Have
8.8 rear cover Have
Moser axles Have
Mini tube Have
disk brakes for rear Have
93 Cobra Master Cylinder
94-95 Mustang Booster
Adjustable Proportioning Valve
E-Brake Cables
Ladder bar set up
Fuel lines
Fuel pump
Corvette Fuel filter
Roll cage
Race seats
Steering Wheel Have
carpet
Head lights
Tail lights
Radio speakers
Tint
Paint
NotchLS1 is offline
post #4 of 26 Old 06-17-2011, 01:18 PM Thread Starter
Parts i bought already:
31 spline trac lok carrier and my gears
went to the junk yard this morning and picked up this rear disc brakes for the rear, need to order a nice set of rear rotors and pads
NotchLS1 is offline
post #5 of 26 Old 06-17-2011, 01:19 PM Thread Starter
Mini tub kit
got my gear install kit
axles and rear end cover Moser makes badass ####!
NotchLS1 is offline
post #6 of 26 Old 06-17-2011, 01:21 PM Thread Starter
I ordered my Moser c clip eliminators and Aerospace front brakes, those should be here next week... I would like to work on the rear end this weekend if i have time, i need to get my axle tubes welded, i need to take the rear to my buddy's shop and get that done
NotchLS1 is offline
post #7 of 26 Old 06-21-2011, 03:31 PM Thread Starter
Got these bad boys in
NotchLS1 is offline
post #8 of 26 Old 06-23-2011, 11:43 AM Thread Starter
C clip eliminators are in
NotchLS1 is offline
post #9 of 26 Old 06-24-2011, 01:19 PM Thread Starter
rear wheels are in!
I test fit them in my camaro to see how they fit they fit pretty good don't need to grind the caliper like most 15" x 10" wheels do with 4th gen's they do however stick out about an inch. i would love to test fit them in the mustang but im still driving it around using it as a daily i don't want to take it apart just yet
NotchLS1 is offline
post #10 of 26 Old 06-26-2011, 09:08 AM
looking good. The F-body requires a 7.5 backspacing as the mustang will require a 6.5 I believe. So there is where the inch is.
XplPerformance is offline
post #11 of 26 Old 06-27-2011, 12:10 AM
evil9t5's Avatar
By any chance did you buy this notchback from the whittier area? Reason I ask is because I actually met up with the guy to check it out before I bought it but passed on it due to the tranny seeming like it was starting to slip. Nice project by the way.
1993 mustang 4 cyl coupe (sold)
1995 mustang gt all stock besides prochamber o/r h pipe,Flowmaster catback,c/c plates,strut tower brace,BBK lowering springs,mgw short throw shifter,BBK Cai
evil9t5 is offline
post #12 of 26 Old 06-27-2011, 04:12 PM Thread Starter
hahaha yes this is the one, trans slips pretty bad but still takes me to work every day, my plans are to buy as many parts as i can, i hope i can get them all by Dec/Jan then start taking it apart paint it and install everything.
Tires are in! i picked them up sat, my baby was enjoying them!
I also took my rear end to my buddies shop to get the axle tubes welded, i would've loved to weld up the cross braces but they have not shown up yet, i am going to have to install that later. We also pressed in my C clip eliminators those are ready to go in... im just wondering if i should wait and get the cross brace welded and also the rear coil over brackets welded in before i oil up the rear? i also set up my front brakes they look great!!!!!
I also got some small parts in
this is the brake pro valve and a hand brake line
NotchLS1 is offline
post #13 of 26 Old 06-28-2011, 12:05 PM Thread Starter
Alright more parts came in, im so close to finishing up the rear its not funny, its another 1G! to finish it up still need the discs, pads, upper and lower control arms, coil over spring and shock, and solid bushing.
here is the two rear brake cables for the parking brake
here is the coil over bracket for the rear end, missing the coil over kit
NotchLS1 is offline
post #14 of 26 Old 08-16-2011, 02:23 PM
Any more progress?
jaysslow9t3 is offline
post #15 of 26 Old 02-15-2012, 06:46 PM Thread Starter
Yes sorry i forgot to update this forum, i took a break on buying parts during the xmas and new years, i finally took out the motor, not sure if i mentioned on here that i am going LS3 with a 6L80E i sold the ls1 short block i had... i am working on the car every weekend with my buddy here are some pictures i forgot to post on here.
Well i got some more goodies in, i got in my K member, lower front a arms, caster camber plates, rear lower a arms, rear upper a arms, and my anti roll bar set.
i also picked up my seat brackets from a guy on C-list for $40 for both to use with my race seats, great deal, the company i bought my race seats wants $99 each bracket! crazies
NotchLS1 is offline
post #16 of 26 Old 02-15-2012, 06:47 PM Thread Starter
i got my roll cage, that was pretty quick shipping! i got a chromoly 10 point cage, can't wait to install it!!! its gonna look funny as hell in a stock 4 cly slipping ass trans mustang LOL
i got my TB in yesterday ####er was pricy! i noticed that i am going to have to change over to a camaro water pump! the truck one is hitting the TB so i need to get one...
NotchLS1 is offline
post #17 of 26 Old 02-15-2012, 06:48 PM Thread Starter
a little update... John and I removed pepe's little heart this past weekend
NotchLS1 is offline
post #18 of 26 Old 02-15-2012, 06:48 PM Thread Starter
i threw away the old trans but couldn't throw away the motor, trans was messed up and motor was still good so i put the motor on an extra engine stand just to get it out of the way,
here are some pictures before we gutted the whole engine bay removed front bumper fenders old k member.
Chuy came over and started welding up some holes, we noticed after he started covering up the holes that it would be easier just buying premade panels that covers up all those holes looks much nicer so i will be ordering those panels tomorrow and hope they come in by friday to get hem welded on.
all bones
fenders and front bumper
John was taking care of the dash, i am not going to run a/c or heater so all of that is coming out, my roll cage is a 10pt has a bar that goes behind the dash as well so it had to come out.
we are also going to paint the whole inside black.
NotchLS1 is offline
post #19 of 26 Old 02-15-2012, 06:55 PM Thread Starter
I ordered some engine bay panels instead of welding up all those holes from the engine bay, those should be in next week, i also returned the throttle body, because i will be running drive by wire, I also ordered the brake booster and mc to finish up the brakes parts, i'll post more pictures every week, i am hoping to finish it by the summer
NotchLS1 is offline
post #20 of 26 Old 02-15-2012, 07:52 PM
Trader Feedback: (30)
Keep us posted man,................. Real cool build
10 sec 2001 Bullitt
5.0 Mustang & Super Fords Magazine - October 2011 Feature Car
twin051302 is offline
post #21 of 26 Old 02-20-2012, 12:25 PM Thread Starter
Not a lot to update but here is where we stand, we might drop the old rear end and cut the rear floor area tonight getting it ready for mini tub's and rear suspension
I also got my trans in 6L80E
Got my headliner redone suede came out really nice, had to get this done before the roll cage or else it would've been a bitch to install it with the roll cage.
we washed and cleaned the engine bay prepping it for the engine bay panels that i ordered.
inside is completely gutted
gas tank is out and rear end should be out this tonight
there is a dent we need to fix on the driver side so we kept the doors on, so it can be lined up with the door jams
NotchLS1 is offline
post #22 of 26 Old 03-02-2012, 09:36 AM
hey where did you buy the panels to clean up the engine bay?
peregrine32 is offline
post #23 of 26 Old 03-02-2012, 10:33 AM
NastyNotch306's Avatar
Nice build! did you go with the Scott Rod Fabrication panels? I ordered mine at the beginning of the week.
"The world is a playground, you know that when your a kid, but somewhere along the way, everyone forget's it"
NastyNotch306 is offline
post #24 of 26 Old 03-03-2012, 05:22 PM
2stangcoupes's Avatar
Trader Feedback: (43)
so is this going to be a race car,or just an all out street brawler
The internals may support 800HP, but that block will spilt faster than a virgin on prom night!
2stangcoupes is offline
post #25 of 26 Old 05-19-2012, 12:39 AM
any updates? cool build
1988 Coupe
TAPIA93LX is offline
post #26 of 26 Old 05-31-2012, 12:21 AM
Yellow5speed's Avatar
Cool. I always had tons of respect for those LS engines.
98GT-PI H/C/I, Pypes O/R X-pipe(CRAP), Flowmaster catback(CRAP)-SOLD
99Z28-stock
Yellow5speed is offline
For Sale 1989 Mustang LX 5.0L FULLY BUILT/RESTORED/Custom Dash! BOSSGT Mustangs For Sale/Wanted, 1987-1993 1 05-29-2011 07:43 AM
For Sale 1993 mustang coupe notch c4,built $6000 pa drexel Mustangs For Sale/Wanted, 1987-1993 3 04-25-2011 01:29 PM
For Sale 1986 Mustang Notch Roller / Project FS Dman03GT Mustangs For Sale/Wanted, 1979-1986 5 01-09-2011 10:10 PM
