real world $$$$$ for lsx - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 10-24-2010, 03:02 PM Thread Starter
5.0mustang5speed's Avatar
again looking into the lsx motors for my new build, 1980 notch stang, i am looking for some real world true dollar figures on the ls motor install..please include the size of the motor..5.3-6.0 etc..heads used, headers, intake or carb-or injection, everything you bought , rather it was new or used and how it came out, e.t times
1962 falcon stock 1992 302 short block, RHS heads, 1.5 inch headers ..bullet cam ..victor jr.. [email protected] on 26x8.5 inch slicks with 1962 suspension(under construction getting back halved)
1979 zephyr , 393w, bone stock 1979 suspension on 26-8.5 tires [email protected]
5.0mustang5speed is offline
post #2 of 9 Old 10-24-2010, 03:31 PM
91 coupe full interior
05 6.0 LQ4 with 41K miles 1100
used 244/250 .612 .620 cam 150
used ported 317 heads with patriot gold springs 600
used gm intake off ebay 99.00
pro-systems carb high priced 620
new ls6 timing chain i think it was 80 bucks
new push rods 80 bucks
So far best to date is a 6.79 @ 103mph. Car should weigh around 3100 with me in it. Thats with a 4:11 gear with a small 3k stall. My 60 foot not that good cause of stall only a 1.53. Gonna get a restall around 4 or so and try again. Hope this helps
98 Z28 M6 with a few bolt-ons best pass 12.31 @ 111mph, 7.89 @ 88mph in the 1/8th with a 1.73 60'
New project 91 mustang coupe LSX swap
key3 is offline
post #3 of 9 Old 10-24-2010, 03:51 PM Thread Starter
are you using the msd box ? what about the headers
post #4 of 9 Old 10-24-2010, 04:10 PM
oh yea sorry I got the msd new for 280 and the header are dynatech which I bought off somebody but they where new and I gave 400 for them.
key3 is offline
post #5 of 9 Old 11-02-2010, 02:50 PM
Gearhead559's Avatar
what about trans? fuel system? and so on. not a real world total if you ask me.
Gearhead559 is offline
post #6 of 9 Old 11-02-2010, 09:48 PM
93 coupe
2002 LQ4 101k miles assembly with harness and computer $1030.00 delivered
2006 GTO MN12 6speed 18k miles $1400.00 delivered
2009 Z06 clutch assembly new $327.00 shipped
AJE kmember with mounts $360 shipped
fuel system, aluminum line, c5 filter/regulator and pump $240.00
Wilwood clutch master cylinder $50.00
booster, master, proportional valve, pbr fronts, spindles, rear calipers, $800.00
rear control arms $109.00 ebay
front poly bushings, $39.00
shifter $25.00 ebay
radiator 99 Camaro $40.00 ebay
Still need
headers $125.00 Jegs uweld it
exhaust $100.00 Jegs X pipe
abbott speedo cablex $350.00
oil pan $350.00 f body or ctsv
tires $500.00
Off the top of my head I think thats it. If I remember more, I try to add it.
Tim Zenger is offline
post #7 of 9 Old 11-03-2010, 09:49 AM
I did it the stupid way, but will make more power in the end. I went 408, higher compression setup, instead of sticking with a stock motor.
I also did everything new, instead of used.
Just on the LS side of things:
408: Machine work, block, internals, gaskets: 6500
L92 Heads + work done to them: $900
Cam kit, with upgraded springs .675 lift: $870
Trans with stall: $1500
Fuel: $700
AJE Set up: $350
MSD: $150
Intake: $275
Carb: $200
Headers: $600
Yeah $12,000. Pretty silly, but again, I bought everything new, the bottom end is top notch, I got the head work done for cheap on a favor, heads flow 352CFM now. I could have gotten everything used, stuck with a stock motor and sprayed this piss out of it, thrown a huge cam in it and run 9s, but I'm hoping with the set up I have I run bottom 9s on spray, and with more convertor maybe even kiss up to a 8.99.
tunink is offline
post #8 of 9 Old 11-06-2010, 03:39 AM
1988montecarloss's Avatar
i can buy 5.3's from a local salvage yard for $200-$500 depending on year and mileage. and i can buy 6.0's from the same place for $600-$1200 depending on yr/miles
1992 mustang GT with a mildly built 331
Originally Posted by GrayGhost331 View Post
Bcam or Bscammed.
1988montecarloss is offline
post #9 of 9 Old 11-06-2010, 03:43 AM
what'd you use for a transmission? and how did you mount the motor in the car? did you use the stock crossmember?
Bcam or Bscammed.
Real World MPG for 11 GT? gobraphil S-197 Mustang GT (2011-2014) 66 10-04-2011 09:08 PM
nx real world power? bluepride SVT & DOHC 11 02-09-2005 09:38 AM
Real world HP tales and new TB... chris93gt 5.0/5.8 Engine Tech 0 01-11-2003 04:45 PM
lowered in the real world RedRyder GT & SOHC 1 12-04-2001 10:08 PM
