86 Notch LQ9 Swap..K-Member/Headers/Intake Questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-10-2010, 12:21 AM Thread Starter
Hey guys I've got an 86 coupe I'm going to be putting an LQ9 into but I have a couple of questions. I already have the motor and I bought the coupe with a 4.6 K-member already in it. I understand this K-member can be used without too much trouble, however what kind of headers are you guys running with this k-member? What clears and what doesn't? Does anyone know?
Also does anyone know if using a 4.6 k-member with stock 4.6 motor mounts will allow the LQ9 with the trunk intake to fit under the stock fox body hood?
Appreciate the help, thanks!
Dman03GT is offline
post #2 of 3 Old 10-10-2010, 01:48 AM
the intake will not fit under the stock hood. you will need to swap it for an ls1 ls6 manifold.
92 notch. Ls powered
http://www.youtube.com/watch?v=zZR9QkF4kcA
ls1fox is offline
post #3 of 3 Old 10-28-2010, 03:02 PM
Dimitri all you have to do is text me. Truck intake wont clear stock hood. Dynatechs for the swap should fit. If your using 4.6 kmember what steering shaft are you using? Thats going to be the only factor really that I can think of.
1990gt
306,Novi 2000,C4.
orangecapri is offline
headers/exhaust hit after k member swap d_dogg07c 94/95 Tech 4 04-19-2010 05:42 PM
k member swap questions 2slow93gt General Mustang Tech 9 07-19-2008 11:47 PM
K-Member swap questions get_som General Mustang Tech 0 12-11-2007 12:39 PM
Wanted aje k-member&headers 4 sbc 4 my 92 notch BIGCOWL-IMP Suspension 0 05-12-2007 07:53 AM
New Member with some serious questions FOUR CYLINDER v-8 swap Nathan Plemons General Mustang Tech 5 04-13-2006 04:41 PM
