98 T/A Engine and Trans in 95 Stang? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 09-12-2010, 09:08 PM Thread Starter
I wrecked my 94 GT and bought a 95 V6.I am in the process of swapping the engine and trans over to the 95.
Last weekend I bought a wrecked 98 Trans Am with a 6 speed for a 1000$.Since I already have the engine out of the 95 I was thinking about installing the LS1 and 6 speed in the 95 instead of the 5.0 from the 94 stang.
Can I use the factory headers from the T/A? If not what ones should I get?
What about oil pan clearance,etc? Thanks,Carl
Edit: I found a link with the info.I am going to go ahead and just swap the 5.0 over and keep the ls1 for my 56 ford.
Nogoodnamesleft is offline
post #2 of 15 Old 06-23-2011, 11:51 PM Thread Starter
Well after fitting it in my 54 f100 and 56 car.I ordered an aje k member and mounts to mount it in the 95 stang. I am not sure if I am going to us the t56 or go with a 200r4 that I have in the shop.
After I get the k member in, I will make up my mind.
post #3 of 15 Old 07-03-2011, 01:03 AM Thread Starter
If you order the aje kmember make sure you order the spring perches also.
post #4 of 15 Old 07-03-2011, 09:22 PM
Imajeenyas608's Avatar
I've got 2 brand new sets of spring perches I'll sell cheap if you need them
Imajeenyas608 is offline
post #5 of 15 Old 07-03-2011, 09:30 PM Thread Starter
Thanks for the offer but I have already got them and installed.I still need to make up mind about the trans.Hopefully I will have some time tomorrow.
post #6 of 15 Old 07-03-2011, 10:30 PM
2stangcoupes's Avatar
Trader Feedback: (43)
so you scored a ls1 drivetrain for a grand? damn thats a steal
2stangcoupes is offline
post #7 of 15 Old 07-03-2011, 11:34 PM
I see that now! I misread the post
post #8 of 15 Old 07-04-2011, 10:06 PM Thread Starter
Yes ,it does have 160k on it.But I could not pass up the deal.
I got it in the car today.I am going to go ahead and us the t56.I just need to make up my mind to keep it efi or go carb.
post #9 of 15 Old 07-05-2011, 12:50 AM
itsslow98's Avatar
I hope you took the opportunity to make a mount for the clutch master before you got the motor in the car.
itsslow98 is offline
post #10 of 15 Old 07-05-2011, 09:57 PM Thread Starter
I have to take it out again.I was test fitting for the trans x member and to cut the floor for the shifter.
I still need to buy a slave and master. Any tips you can give me?
Thanks,Carl
post #11 of 15 Old 07-05-2011, 11:50 PM
itsslow98's Avatar
Thanks,Carl
Go with a wilwood smaller unit or if you have the room a tick adjustable master. And try to measure where your headers are gonna sit now before you pullt he motor back out. Trust me, if you can mount it once and make it work itll make life 50 times easier then trying to redo it when the motor and trans are already in the car.
I Had it mounted and had to redo it when I found out how ####ty the kooks headers made specifically for the swap fit. And I had to redo it while the motor was in the car lol.
post #12 of 15 Old 07-06-2011, 01:15 AM
Foxman1992's Avatar
Trader Feedback: (39)
Stock 2010 camaro manifolds work great lots of clearance!!!!!
http://img.photobucket.com/albums/v473/Moench/foxman-1.png
Foxman1992 is offline
post #13 of 15 Old 07-11-2011, 11:29 PM Thread Starter
Thanks for the advice. I have had to work 7 to 6 with an hour and half commute.I have not had time to mess with it.
I plan on getting back to it this week.
post #14 of 15 Old 07-15-2011, 11:12 PM Thread Starter
I took you guys advice.I just today got my 2010 camaro exhaust manifolds in.I held them up to each head,they do look like a great fit.
I also orderd a wilwood l inch mastercylinder.I also have a new oil pan gasket,rear main and throwout bearing.
Tomorrow I hope to get the exhaust and maybe the clutch master and line fabbed up. Thanks again for the input.Carl
post #15 of 15 Old 09-08-2012, 09:21 AM Thread Starter
I have a sad update. Due to time and money to finish it I had to put the old 5.0 t5 back in it to get it going.
I had to the engine and trans in, drive shaft hooked up(stock shaft with t56 yoke).
The 2010 exhaust manifolds do work ,although I had to do a little grinding for the steering shaft.
I had the clutch pedal assy in and was fighting getting the dang thing to bleed..............
and with selling the wives car and us needing something to drive and a daughter in college......
We needed it on the road again.So out comes the ls1 t56 and in goes the 5.0.
It was not a total waste of time though.With the aje k member it does handle a lot better and tighter.
I did go ahead and convert to carb with my 5.0.
I plan on saleing the t56 to get some cash.Right now I have the ls1 setting in the frame of my 54 ford.Thanks for all your help.Carl
complete 2.3 engine and trans for 89 stang bpandolfi 2.3L Engine Parts 10 03-14-2006 10:37 PM
my 95 trans am for your stang Grannycar Mustangs For Sale/Wanted, 1999-2004 2 03-14-2005 09:47 PM
1998 5.0 GT40P Explorer Engine. Good Stang Engine Swap!!! flynbrian Windsor Engine Parts 0 03-06-2005 06:34 PM
1998 GT40P Explorer Engine! Make Nice Stang Engine! flynbrian Windsor Engine Parts 2 03-06-2005 12:09 PM
WANTED 87-93 STANG, W/OUT ENGINE/TRANS cobra11182 Mustangs For Sale/Wanted ARCHIVE 9 11-06-2003 04:24 PM
