2002 6.0 help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 08-11-2010, 12:18 PM Thread Starter
Notchfire's Avatar
2002 6.0 help
I have access to a free 2002 6.0 out of a 3/4 ton silverado.
What block/heads are these? lq9? lq4?
Thinking of putting this into my 1990 LX
Thoughts? Advice? I like the idea of fuel injection.
hatch on 275's. where's the confusion?
Notchfire is offline
post #2 of 15 Old 08-11-2010, 04:02 PM
it is going to be an lq4, which is a lower compression lq9. still a great engine, same rods, crank, block, heads, intake, etc. as the lq9 just different pistons.
i am balls deep into a lq9/coupe swap right now and i just have to say, be ready to spend more then you plan. i am doing an lq9, th350 w/sbc converter (and gm adapter), 4th gen lt1 radiator and fans (thicker then the ls1 radiator and bolts in perfect), 351 swap headers with ls1 flanges welded on, aje k-member and crossmember, custom driveshaft, custom pcm with modified stock harness, and the list goes on. there are cheaper ways to go fast, but i am a die hard gm guy and picked up a coupe roller that has over 10k in just suspension, brakes, wheels/tires, and cage so i plan to make some serious power.
dville_gt is offline
post #3 of 15 Old 08-11-2010, 06:57 PM Thread Starter
Notchfire's Avatar
Very Cool! So, could I use the stock longblock with a cam swap and make any kind of power? Looking to stick with fuel injection. BTW it's going into a very light hatch roller that I built.
post #4 of 15 Old 08-12-2010, 08:29 AM
Yes you can do that. You can also throw in some lq9 or ls2 flat tops and bump the compression up in the 10's.
amicksLS1 is offline
post #5 of 15 Old 08-12-2010, 12:45 PM
when i have the money i will switch to l92 heads with victor jr., that setup yeilds over 500hp with the right cam.
post #6 of 15 Old 08-12-2010, 03:21 PM
Just an fyi, a 5.0 radiator will work. stock 5.0 upper hose cut and modded a little and a 2.3 stock lower hose. stock 5.0/5spd driveshaft will work with a turbo 350 with long tailhousing. Just get a conversion ujoint and a th350 yoke. stock trans crossmember will work also with a modified t5 mount. Mines done and this is what I used.
1990gt
306,Novi 2000,C4.
orangecapri is offline
post #7 of 15 Old 08-12-2010, 04:45 PM Thread Starter
Notchfire's Avatar
All great info! Planning on doing the AJE kmember and kooks headers.
What would be a good choice for a efi intake if I use the L92 heads?
post #8 of 15 Old 08-12-2010, 05:51 PM
Havent done l92 heads so dont know on intake. Look into the dynatech headers over the kooks.
1990gt
306,Novi 2000,C4.
post #9 of 15 Old 08-13-2010, 08:25 AM Thread Starter
Notchfire's Avatar
Whats the best way to buy L92 heads? Bare or complete? New/used? What should I expect to pay?
post #10 of 15 Old 08-13-2010, 11:45 PM
same rods,
nope. rods are beefier in the LQ9.
R0B0T is offline
post #11 of 15 Old 08-13-2010, 11:55 PM
i researched l92 heads, and i decided to go with some prc stage 2.5 cnc ported heads instead... it came out to be about $350 cheaper that way to have a comparable head given the info that is out there. don't forget, with the l92 heads you need new intake rockers (might be exhaust, i dont recall). the intake valve is bigger and heavier. and the exhaust ports are "smaller" than the cnc ported stock casting budget heads. it seemed to me that the guys with real well running l92 headed motors had to fly cut the pistons for the exhaust valve(cam grinders had it open longer). at least the guy that i was researching his combo did.
take this at face value, do you own research before you come to any conclusions.
R0B0T is offline
post #12 of 15 Old 08-14-2010, 11:16 AM Thread Starter
Notchfire's Avatar
What do the PRC heads go for? Seems the l92 are around $500 bare/pr
post #13 of 15 Old 08-14-2010, 07:53 PM
i think mine were 1200 milled for smaller chambers, ti retainers and keepers, ".675" springs
R0B0T is offline
post #14 of 15 Old 08-16-2010, 11:49 AM
Later model lq4's have the ls2/lq9 rods. Mines an 05 and does.
1990gt
306,Novi 2000,C4.
post #15 of 15 Old 08-16-2010, 12:38 PM
orangecapri, i sent you a pm!
2002 gt mani GT & SOHC 3 05-29-2007 04:30 PM
2002 GT in PHX F.S. GTG Mustangs For Sale/Wanted, 1999-2004 1 07-18-2005 10:53 PM
2002-2002 Saleen S281 Convertible Wanted LivinNiceJ78 Mustangs For Sale/Wanted, 1999-2004 0 02-04-2005 07:14 PM
Any S/C 2002 GT Help. SG2002GT GT & SOHC 10 12-01-2002 12:42 PM
2002 gt slantman Lounge 15 11-21-2002 11:20 PM
