545 Ci BBf or LSX - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 28 Old 01-04-2010, 08:11 PM Thread Starter
5.0mustang5speed's Avatar
545 Ci BBf or LSX
looks like i will have some decent $$$ to play with soon, with tax time around the corner, i am having a hard time deciding on a LSX 6.0 with L92 heads or a 545 ci BBF , i want to run 9.90 or faster
1962 falcon stock 1992 302 short block, RHS heads, 1.5 inch headers ..bullet cam ..victor jr.. [email protected] on 26x8.5 inch slicks with 1962 suspension(under construction getting back halved)
1979 zephyr , 393w, bone stock 1979 suspension on 26-8.5 tires [email protected]
5.0mustang5speed is offline
post #2 of 28 Old 01-04-2010, 08:24 PM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
i would think it would be easier and cheaper with the LSx.
smaller package, a lot lighter, make the same power with the same ease.
just my opinion.
2001 Mustang GT Bullitt (terminated) #2793
2015 GMC Sierra 1500 4x4
2015 Chrysler 300 S
eleanorfox is offline
post #3 of 28 Old 01-04-2010, 08:57 PM Thread Starter
just my opinion.
im open to all opinions, i have no experience with the lsx motors, i would like to learn, on the other end i know a 545 with good heads will make 700+ hp, on the down side a good set of heads to feed a 545 motor cost about 3k, i will only have about that to spend on the car
post #4 of 28 Old 01-04-2010, 09:02 PM
Moderator
eleanorfox's Avatar
a built LSx with some spray can make that too, on stock GM heads.
2015 Chrysler 300 S
post #5 of 28 Old 01-04-2010, 09:02 PM Thread Starter
i think i could build a LSX motor for what i have to spend and headers
post #6 of 28 Old 01-04-2010, 09:05 PM
Moderator
eleanorfox's Avatar
it would be pretty kick ass.
i would be willing to bet that a 550-600 HP lsx with go just as fast as a 700hp big block just because of the weight diff.
2015 Chrysler 300 S
post #7 of 28 Old 01-04-2010, 09:15 PM
Rock4451's Avatar
LSx would be a great idea, very stout engine with tried and true potential. Can't beat the new technology of the LSx either. Just keep it in the same chassis as the company that made the motor and it will be kick ass.
86 Mustang 302 N/A
372rwhp/349rwtq
Rock4451 is offline
post #8 of 28 Old 01-04-2010, 09:16 PM Thread Starter
i do not want to use nitrous,i want a fast bracket car, found several 6.0 motors , for 500.00 there is one on CL that came from a esclade that already has L92 heads , for 500.00
post #9 of 28 Old 01-04-2010, 09:54 PM
pkstang's Avatar
Trader Feedback: (161)
Smile
the only problem with your theory is that its actually torque that matters
pkstang is offline
post #10 of 28 Old 01-05-2010, 02:27 AM
+1
97BlackSteed is offline
post #11 of 28 Old 01-05-2010, 07:42 PM Thread Starter
Originally Posted by 97BlackSteed View Post
+1
i hate camaros and firebirds...fox body all the way
post #12 of 28 Old 01-05-2010, 07:56 PM
thats a deal, BUY IT, the esclades have aluminum blocks too, even lighter.
Street car with a 5 speed
427ci SBF -- 9.86 at 136mph
http://youtu.be/2GKQ2xpZraU
Drag Week 2013 SR/SB/NA Winner
Doc's Notch is offline
post #13 of 28 Old 01-05-2010, 08:08 PM Thread Starter
i will not have the $$$ till next month here is the post
http://wichita.craigslist.org/pts/1523969907.html
post #14 of 28 Old 01-06-2010, 09:26 PM
5.0fox's Avatar
yeah.......but will it sound as cool
93 5.0 edelbrock performer H/C/I, bbk lt's, O/R H pipe, flowmasters,255lph pump, 75mm pro-m bullet, 24lb/h inj, 70mm tb. bbk cai.
5.0fox is offline
post #15 of 28 Old 01-12-2010, 02:56 PM
Rather see a bbf .
csgoody is offline
post #16 of 28 Old 01-14-2010, 12:20 PM
Raceallday1's Avatar
Location: Troy,Al, at work, in the shop, or at the track.
Since a complete aluminum headed 545 BBF can be built for less than $6000 complete, I think the choice is obvious for a 9.90 car. Add minitubes, UPR suspension, adjustable coil overs, and some 12" slicks and you'll have a low 9 second all motor car with a less than $6000 motor.
Do more research and see just how cheap the BBF parts are.
1969 fastback street car project underway.
Beware of leftist/liberals/democrats posing as Americans.
Raceallday1 is offline
post #17 of 28 Old 01-14-2010, 03:27 PM
I'd like to see this 545 for under 6k, care to make a parts list with prices?
post #18 of 28 Old 01-14-2010, 05:16 PM
6.0L LS motor with 2 small turbos and about 8psi will feel like
a 600" big block.
r.barn is offline
post #19 of 28 Old 01-14-2010, 07:15 PM
Quick summary:
Complete heads from Jegs: $2100
Rotating assembly w/rings and bearings: $1500
Carb: $800
Intake: $300
Headers: $400
Cam/lifters/push rods: $450
This is a slight over estimation in prices but covers the most expensive stuff.
Obviously buying used saves a lot of money.
post #20 of 28 Old 01-15-2010, 08:32 AM
Quick summary:
Carb: $800
Intake: $300
Headers: $400
Thats 5500 bucks before machine work, and you dont have a block rockers, valve covers, timing chain, balancer etc. That would be an 8-10k dollar build easy. There is 6k just in parts.
post #21 of 28 Old 01-15-2010, 12:09 PM
Complete used motors can be bought from a Pull-A-Part for less than $100. BBFs require very little machine work to the blocks, usually boring isn't even necessary. Valve covers? $150 at the most, and that's for the tall FMS cast aluminum. Chain and balancer might cost $200 for both. All that together does not at up to $4-5000. extra. Plus, used parts like intakes, carbs, headers, oil pans, and even heads cab be bought at a fraction of new price. No need for super expensive parts because a 545 ci motor doesn't need a lot rpm to make big hp.
post #22 of 28 Old 01-15-2010, 08:46 PM
Sprayaway Fox's Avatar
Personally I would do a LS combo. That coming from a Dart blocked 347 guy. auto camaros by me on some gas are running 10.60's and they drive it everywhere, I MEAN EVERYWHERE. Pumpgas on the street and good gas at the track.
Sprayaway Fox is offline
post #23 of 28 Old 01-15-2010, 11:23 PM
Well I plan on 'bout $8gs for my notch with BBF. I'd Like to know what some of these "low buck" LSx mustangs have in em money wise?? Not say'n a stock bottom end 6.0,l92 heads,carb intake and 200 giggle pill can't run high 9s/Low 10s? I would think 350ci+ 300cfm head and heavy dose would.
What are some of the LSx swap guys got/gonna have in their setup dollar wise? My $$$ # is with susp. front and rear,engine+tranny. But I'll be happy with a solid 10 second slip on all motor from my combo.
But a 5.3 or 6.0 good h/c/i with a 76mm does sound tempting................
......................in a GM body!
Wicked-One is offline
post #24 of 28 Old 01-16-2010, 11:11 AM
jw33's Avatar
People are getting the l92 motors for around $1000-2000 with the tranny and accesories. You then need a carb intake, carb, headers, cam, springs, stall, misc.... It's all probably within 2-3000 of each other.
jw33 is offline
post #25 of 28 Old 01-16-2010, 01:59 PM
Louis Rowe's Avatar
I have seen complete motors used for 6 grand that would run mid to low 9s.
Just look at Feetfirst on here he was selling motor a 501 that ran well in the 9s for 6,000.
Louis Rowe is offline
post #26 of 28 Old 01-16-2010, 02:03 PM
chrisa351's Avatar
LSX is a great idea. I have had a 98 SS Camaro and a 598 inch BBF which was impossible to keep together. Do some research on bbf oiling problems and you will choose the LSX.
I cant stress enough, BBFs have oiling issues which really show up when raced,
you can make a ton of power with them but you gotta buy good heads and modify the oiling system. Plus think about the weight issue.
BBF dudes dont flame me as one of my old 557 motors is still running in a low 9 sec ranger. I respect them alot.
I just think the LSX is the better choice. Although you will prob need a power adder to get to the 9s.
I think you would have a much easier time getting into the 9s on motor with a BBF though....
If I was gonna do it id buy a BBC....you cant beat them for HP per dollar.
The only reason I have a SBF in my car is I had a trans, elec water pump, intake, dist, headers cam and heads already.
Go the track and see what most bracket cars are using....BBC.
Anyone can sit in the stands and talk s**t. Get out there and RACE!!!
PT76GTS blowthrough...sold. Cool but not what I wanted.
was running a 14 to 1 Man O War 427 with High Ports.Sold.
now running a 412 Windsor with Vic heads and a .700 solid roller
chrisa351 is offline
post #27 of 28 Old 01-16-2010, 09:54 PM
faststang90's Avatar
go here for oiling on a bbf.
http://www.highflowdynamics.net/
the reason y most drag race cars have chevy motors is because u can find parts easy. both motors will get u to run them times just on what kind of money u are wanting to spend.
faststang90 is offline
post #28 of 28 Old 01-16-2010, 09:59 PM
Pro Stock John's Avatar
Here is an article I did on a guy's L92-headed 6.0 setup in a 88-92 Mustang:
http://www.planetlsx.com/vehicles/Ch..._with_L92s/107
I was so impressed with his car that I'm building the same setup in a 2000 Z/28 only I will use an aluminum block.
Co-founder
1951 Mercury custom lead sled
2010 Camaro SS [email protected]
Pro Stock John is offline
WTT 2002 mustang with a 545 BBF Nitro Lew Other Fords and Trades 6 07-27-2009 07:50 PM
AWSOME 2002 with a BBf 545 Nitro Lew Mustangs For Sale/Wanted, 1999-2004 11 05-29-2009 09:30 AM
2002 BBF 545 update pics Nitro Lew Lounge 32 02-05-2009 11:28 PM
2002 with a 545 BBF build Nitro Lew General Mustang Tech 2 09-26-2007 11:37 AM
F/S BBF 545 nxcobra545 351C/BBF Parts 5 06-16-2006 09:41 AM
