WTB Idle Air Control Adjuster - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
  • 2 Post By indy2000
post #1 of 15 Old 03-18-2019, 09:31 PM Thread Starter
rosecroft's Avatar
Trader Feedback: (41)
Wtb idle air control adjuster
hoodlar
rosecroft is offline
post #2 of 15 Old 03-19-2019, 03:41 PM
indy2000's Avatar
what is that?
indy2000 is offline
post #3 of 15 Old 03-19-2019, 04:01 PM
92BIGREDBEAST's Avatar
IAC? Parts store nearest you...
92BIGREDBEAST is offline
post #4 of 15 Old 03-19-2019, 05:01 PM
Please call me Mike
mr_minnis's Avatar
Trader Feedback: (46)
I think he wants the spacer that goes behind the iac that can limit airflow across the IAC. You adjust 2 set screws.
84K 88 LX Vert 5spd: 3.73s.
mr_minnis is offline
post #5 of 15 Old 03-19-2019, 05:18 PM
AtomicCoupe's Avatar
Idle air adjustment plate. LMR sells them. I fell for the trap, now it’s sitting on my shelf in my garage. Didn’t work for me.
https://lmr.com/item/LRS-9939A/1986-...l-Iac-Adjuster
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is offline
post #6 of 15 Old 04-21-2019, 12:14 PM
Outlaw347's Avatar
Trader Feedback: (32)
I used those for years with modded/stroked nat.aspiration efi setups and worked great.
I bleed Ford BLUE
Outlaw347 is offline
post #7 of 15 Old 04-21-2019, 06:19 PM
indy2000's Avatar
garbage, that is what those are
Cougar5.O and fox88 like this.
indy2000 is offline
post #8 of 15 Old 04-22-2019, 12:30 PM
Outlaw347's Avatar
If your timing and TPS aren't properly adjusted and you don't read the instructions properly you may think it's garbage; worked great for me on a half-dozen of 11,12,13 sec n/a modded street cars and two 306 blower cars. Reduced or eliminated the Rolling idle.
I bleed Ford BLUE
post #9 of 15 Old 04-22-2019, 01:03 PM
theYman's Avatar
Trader Feedback: (26)
I have one and like it.It allows me to make a very fine idle adjustment and has eliminated surging. I bought mine frpm Tasca Ford.
347 Stroker/ TW170 heads /TrickFlow R intake/ FordStroker cam/Longtubes Astro A5
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
theYman is offline
post #10 of 15 Old 04-22-2019, 01:11 PM
I already sold the OP mine that DID NOT work for my application. It did absolutely nothing for me. We re worked the tune and that fixed my issues. Maybe OP can share his experience with the one I sent him. Hopefully it worked for him.
post #11 of 15 Old 04-22-2019, 01:35 PM
indy2000's Avatar
timing is 10deg BTDC, nothing hard there
TPS is NOT adjustable, and is in spec between 0.65-1.15Volts
drag racing and rolling idle problems??.........MINT.
indy2000 is offline
post #12 of 15 Old 04-22-2019, 05:32 PM
Outlaw347's Avatar
Wow what a reply; fyi I never said I had any Rolling idle problems and TPS is indeed adjustable once the factory holes are slotted and then readjusted to optimal .99V with KOEO, but I bet you have no idea what KOEO means right?
I bleed Ford BLUE
post #13 of 15 Old 04-22-2019, 11:52 PM
indy2000's Avatar
I guess that means your MISINFORMATION, makes your reply a richer reply!
truth dont care about your feelings
your post clearly states rolling idle issues.....but that is expected when you have no idea what you spewing about
indy2000 is offline
post #14 of 15 Old 06-11-2019, 01:09 PM
fox88's Avatar
Sorry to tell you, but he's right.
It's not adjustable. Or rather, not meant to be adjusted. When you turn the key, that voltage reading is basically just a check point. That's it. It renews every time you cycle the key. As long as the voltage reading is in between the low and high values, all is good in TPS land.
That .99 BS is all myth from back in the late 80's and early 90's before the EEC-IV had been broken down and reverse engineered. Now today, we know how it all works. And that's how it works. More or less.
FTI TW heads/FTI cam/RPMII/A-trim/T5 & 4.10's/QH w/ BE & EA/GUFB
www.carstereooneinc.com
fox88 is offline
post #15 of 15 Old 06-12-2019, 07:37 AM
vinnietbird's Avatar
Trader Feedback: (139)
I have one. $35 shipped with bolts and gasket
PM me if you want it.
'88 Tbird..Z-Spec T-5,Track Heat intake,BBK CAI,Ed Curtis cam,Twisted Wedge heads,1.6 Scorpions,3G,Mass Air with 24's,75mm t-body,BBK CAI,140 mph speedo,8.8 with 3.73's,BBK shorties,mini starter,O/R H-Pipe, Flowmaster Super 44's, Saleen SC wheels,Taurus fan,CHE control arms
vinnietbird is offline
For Sale Idle Air Control 5.0 Saleen 88-0554 Windsor Engine Parts 1 01-18-2014 02:24 PM
Crank, No Start Blown88GT MegaSquirt DIYAutotune Systems 34 12-28-2013 12:14 PM
Idle air control adjuster FRAN Windsor Engine Parts 1 10-03-2010 11:43 PM
IST MAF air adjuster $150 bellotti50 Electronics and Entertainment 2 08-13-2005 11:05 AM
Idle Air Control Problem - 1987 Mustang 5.0 87whitestang 5.0/5.8 Engine Tech 4 07-21-2005 03:01 PM
