93 hatch turbo build - Ford Mustang Forums : Corral.net Mustang Forum
LinkBack Thread Tools
Old 04-12-2019, 03:29 AM Thread Starter
The car is a 93 hatch that I bought as a roller, with a ls k member (oof). It has an engine and trans out of an 88 fox with probably over 100k on them. I'm doing a cheap mostly all used parts, turbo build.
The car WAS running with the stock bottom end, Explorer intake, GT40p heads (I lapped the valves with a drill and added the Trickflow spring kit #TFS-2500100), and F cam. Unfortunately, the stock oil pump wasn't having the 6k+ rpms and seized up. Well that pretty much destroyed the bearings. This happened when I bought all the parts to fab my turbo kit. So there I was with a pile of parts and a blown engine.
So I pulled the engine and all the bearings were still stock Ford. I replaced them with some King bearings off Amazon. The engine is back together now and I'm starting to fab the hotside now.
I'll be tuning the car myself with Microsquirt. Anyways here's some pics.
machwun is offline
Old 04-12-2019, 03:33 AM Thread Starter
pics
machwun is offline
Old 04-12-2019, 06:53 PM
JFraser27's Avatar
Nice, canít wait to see it up and running again!
Stock bottom end, gt40 top, V1 s trim, TKO, 5 lug, 4 wheel disc, etc
JFraser27 is offline
Old 04-12-2019, 09:48 PM
Looking forward to seeing what you do with it. I would like to tubro my car when it is inspection exempt. I can't decide if I want to try to make my own or buy a kit.
1987 Coupe: Stock 5.0, T5, 4.10s and a spool
russ3747 is offline
Old 04-13-2019, 10:59 AM
Mustangmichael's Avatar
Trader Feedback: (59)
Wow, that driveshaft put up a fight before it snapped! Cool project. I'll be following.
Michael Bell
email:
92 coupe, coyote 5.0, turbo, manual trans, project in progress....
Mustangmichael is offline
Getting a turbo 95 gt, I need advice on this build SpeeDemon7 Turbochargers 25 04-21-2012 11:58 PM
What to build, EFI 408, high comp 347, or turbo 306? Killercanary 94/95 Tech 27 08-16-2003 05:25 AM
OK. I want to build my own turbo kit. LXguy Turbochargers 6 06-27-2003 08:49 PM
want to build a 331 turbo motor!! tording 5.0/5.8 Engine Tech 4 01-21-2003 05:35 PM
want to build a 331 turbo motor!! tording Turbochargers 1 01-21-2003 01:52 PM
