Coil Pack Help? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-08-2002, 03:11 PM Thread Starter
Angry Coil Pack Help?
Cylinder 3 is missing. I have changed the plug and ran injector cleaner through it. Still seems to still miss but hasn't re-tripped the service engine light. Someone suggested I check the coil pack. Where is the coil pack? What does it look like and how can I test it?
YC_YP_YL is offline
post #2 of 7 Old 05-08-2002, 03:17 PM
what year is your car?
96GTSVO is offline
post #3 of 7 Old 05-08-2002, 03:21 PM Thread Starter
99
YC_YP_YL is offline
post #4 of 7 Old 05-08-2002, 03:27 PM
I suggested that you check coil pack.
The 99 & up cars have whats called coil on plug, Which means the coil is located directly on top of the plug. If you have replaced the plug you already have had the coil off.
No Limit Racing is offline
post #5 of 7 Old 05-08-2002, 03:33 PM Thread Starter
Now that I know what you are talking about how do I make sure it is working properly?
YC_YP_YL is offline
post #6 of 7 Old 05-08-2002, 04:05 PM
swap the bad one with a good one by taking it off another good cyl. see if you problem moves with the swap.
SilverStanger is offline
post #7 of 7 Old 05-08-2002, 06:34 PM
blk88gtstang's Avatar
I can't give you the numbers, but you need to test the primary and secondary..... what's the word, you need to test resistance between two differnt points. You need to test across the two harness plug points, and then test between one of the points and the connecting tip at the spark plug end with a multi meter for resistance. I'll check and see, I wrote this up in a thread somewhere else.
Anybody got a Haynes or Chiltons handy?
2006 Nissan 350Z - Daily Driver
1988 Mustang GT - My first car. Parts scattered all over the house.
1998 F150 XLT - Stolen RIP
blk88gtstang is offline
