Those using a fuel pressure safety switch in here please. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-08-2002, 01:45 AM Thread Starter
US Air Force Active Duty
Arrow Those using a fuel pressure safety switch in here please.
Which one are you using and how was the install? What pressure is it set at?
VT cammed 99 Rio Red GT
298rwhp 305rwtq
JMWEEZ is offline
post #2 of 4 Old 05-08-2002, 01:49 AM
cyclical's Avatar
I am using the one from Nitrous Express.. it's only like $36, and I believe it comes set at either 30 or 35 psi.. but you can adjust it. The only problem adjusting it you need a gauge of some sort to measure what it is set at..
cyclical is offline
post #3 of 4 Old 05-08-2002, 01:50 AM Thread Starter
What should it be set at for a 99+ GT with stock fuel pump?
298rwhp 305rwtq
JMWEEZ is offline
post #4 of 4 Old 05-08-2002, 04:10 AM
I'm useing the NOS Fuel Safety Switch (part # 15685) . Ordered it through Summit $34.00
It can be adjusted from 25 to 50 Psi and is very easy to install. All you need is a 12 volt Dc test light. On your car I believe you want it set at 35 psi
If you want email me at [email protected] and later I'll send you a copy of the instructions, so you can check them out.
Stink finger is offline
