Cam Timing Info - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-07-2002, 11:18 PM Thread Starter
Cam Timing Info
Ok I got the cams and cchains on tonight. Just want a little re-assurance that they everything is lined up right.
I couldn't find any bright links so I marked opposite ends of the chains. I lined these links up with the marks on the crank and cam sprockets.
My cd manual says something about one link on one end of the chain and two on the other.???
Is there any good info online or can anyone confirm if I got everything right?
David
tampa99gt is offline
post #2 of 3 Old 05-08-2002, 03:56 PM Thread Starter
TTT,
post #3 of 3 Old 05-09-2002, 01:24 AM
there are 2 differently marked links on each chain.If you hang the chain down they should be parallel to each other. u have to look closely but they are there. line them up with the marks on the cam gear as im sure you already know.
mike
bblown99gt is offline
