Aluminum Driveshaft - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-07-2002, 10:06 AM Thread Starter
Aluminum Driveshaft
What are the advantages and disadvantages of the aluminum driveshaft?
Gary01GT is offline
post #2 of 5 Old 05-07-2002, 10:29 AM
No disadvantage unless you count that your wallet is about $160 lighter.
Weight savings. Far less drivetrain vibration (resonation) after a gear swap. The aluminum d/s can flex 17 degrees compared with the steel one that can flex about 3 degrees. This helps reduce the shock to the rear/axles during a hard launch. I've also seen claims of about 2-3rwhp increase due to some of what is mentioned above but I cannot verify that.
mrvax is offline
post #3 of 5 Old 05-07-2002, 02:19 PM
The driveshaft killed a resonating sound i had at 100mph.I believe like GARY01GT,the tires don't seem to hit as hard.
snake 98 is offline
post #4 of 5 Old 05-07-2002, 02:36 PM
Banned
I think it is an excellent bolt on. I had one for my 90. I am planning on getting one for my 98
post #5 of 5 Old 05-07-2002, 02:52 PM Thread Starter
I was just underneath my car and noticed the muffler was real close to the driveshaft. Is the aluminum shaft the same diameter?
Gary01GT is offline
