Target Air Fuel ratio for NA Cobra 4v? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-07-2002, 08:11 AM Thread Starter
Just used a Bailey AFM-1 on my 99 Cobra. It is lean at 14.0:1 Air fuel ratio at wide open throttle in 2nd and 3rd gears throughout most of the rpm range. Richest I saw was 13.9 at 6200 about. My understanding is that the target should be 12.7-13.0 normally aspirated. What do the tuners normally shoot for on normally aspirated street engines when burning chips?
I don't have a data logger set up yet to take the output from the wide band and an rpm signal and record it real time on a lap top. But I'm working on it.
Joe Lynch
99 Cobra Convert, 99GT live axle, 31 spline C-Locker, Mark Williams axles, HPM upper and lower, FMS alum driveshaft. Pro-Motion pro-shifted TKO-500 trans.
28x10/15 ET Drags on Pro-Star 15x10, 6.5BS wheels Star Stage 3S clutch, MAFterburner Plus, Aeromotive A1000-6 regulator, return style fuel system,
Aug, 2003 forged motor, HP cams, SHM valve springs, short runner intake, SCT Flasher for tuning. Best
150 shot is 10.77 at 127.8 mph in very good air. 1.35 60'.
Joe Lynch is offline
post #2 of 9 Old 05-07-2002, 10:40 AM
BTLFED's Avatar
Dont know if this helps Joe but I remember my A/F Ratio being 13.2 ish NA and 11.7 on spray. I dont think this is a 2V,4V or Mod Motor specific question. I would post this question in Windsor Forum and I bet you get the answer you need.
BTLFED is offline
post #3 of 9 Old 05-07-2002, 12:38 PM
BadBud's Avatar
Joe,
Just lurking and reading, Ive seen that most tuners richen the A/F up one step from like 13.x to 12.x.
I am wondering if gutting the stock MAF would accomplish this as well? I want to buy a spare and carve it up, but I have not found one as yet.
Also, Joe, what do you think of the The RACE Systems SnEEC-IV Real-Time Data Logger?
BadBud is offline
post #4 of 9 Old 05-07-2002, 02:07 PM
Trader Feedback: (37)
Joe, That's really lean. I'm surprised it didn't dentonate. I have an a/f of 13.1 all the way to 6200 then went to 12.5. This was done w/ no chip and just an adj fpr. IMO anything over 13.5 is getting risky. Gotta take into consideration of hot days and bad batches of gas ya know. -Mark
98 red cobra (N/A 5.4)
[email protected] (1.59 60')
bitemark46 is offline
post #5 of 9 Old 05-07-2002, 03:35 PM
Chris98vobra's Avatar
Joe,
I can confirm what others are saying. 12.5:1 to 13.5:1, depending on the engine. Most seem to do best in the upper 12s.
Chris
Chris98vobra
98 Tan on Laser Red Rag Top Cobra
Fully built and forged with Mahle pistons, SHM Blower cams, ported heads/nitrated valves
Novi 2000, 52# RC injectors, custom IC, Devilsown alky injection, SSR Intake, Steeda rails and -8 feed lines, 03 tank + Aviator dual pumps
Tuned with SCT Pro Racer Package (and everything else over the years)
Lot's of other stuff!
Chris98vobra is offline
post #6 of 9 Old 05-07-2002, 04:58 PM
Talking
Jason Meiers and other N/A 4V cars have made the best power at 13.1 A/F ratio...That seems to be the optimal level for the best power on an N/A car...
Jeff
BlackCobra99Va is offline
post #7 of 9 Old 05-07-2002, 09:23 PM
You want an A/F ratio of 12.8 - 13.0 for a N/A 4V
96 Ford Cobra, PHP Stage 2 intake, All the bolt-on's, SVO Ceramic Headers, Bassani Off-Road X-pipe, Borla XR-1's, and The New 4.56's are in!
95 ZX9R Ninja 136RWHP/ 70RWTQ [email protected]
06 2WD TrailBlazer SS 6.0L LS2 395HP Stock
ALLNTRL is offline
post #8 of 9 Old 05-07-2002, 11:29 PM Thread Starter
Thanks guys. I will shoot for the 12.8-13.0 range.
Joe
post #9 of 9 Old 05-08-2002, 12:43 AM
Yeah just to back up what everyone else is saying, Jimmy LaRocca tuned mine at a A/F ratio of 12.5:1. He tried a 13.2:1 and didn't get any more power out of it than the 12.5:1, so he put it back down to keep it from possibly detonating on bad gas. This a/f ratio also gives me more room to play with my timing adjuster.
1996 Cobra (#102)
Most of the naturally aspirated mods.
60': 1.681
1/8: 8.162 @ 84.47
1/4: 12.773 @ 107.74
Pat96Cobra is offline
