What does the Idle Air Controller do?! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-06-2002, 11:58 AM Thread Starter
I really want to disconnect this thing to clean up the engine a little more. I've seen some guys with a tiny K&N on it, any issues with that?
-Ed
Ed Hubbard is offline
post #2 of 7 Old 05-06-2002, 12:21 PM
crownvic96's Avatar
your IAC lets air into your engine at idle when your throttle plate is closed by bypassing air around your throttle.
Justin
1996 Crown Victoria LX HPP Black, white leather. 35% tint
1983 280ZX Turbo, 2 seater, 5spd
Silver/Gray Two tone
Silver/Black leather interior
ALL STOCK 82K MILES
[email protected] w/2.1 60'
crownvic96 is offline
post #3 of 7 Old 05-06-2002, 12:51 PM
I think you need it. I controls airflow at idle and during decel.
David
David Posea is offline
post #4 of 7 Old 05-06-2002, 01:15 PM Thread Starter
Ok, but doesn't sound like the air *has* to move through the MAF (since its probably flowing too slow at idle for the MAF to register corectly). This makes sense now as, for instance, I know Chris Mureen has a small air filter on his IAC & doesn't throw any codes.
-Ed
post #5 of 7 Old 05-06-2002, 02:23 PM
Chris98vobra's Avatar
Hi Ed,
No, I have my little K&N venting my valve covers to the air. My IAC still gets it's air through the main inlet tube on my powerpipe.
The computer feels a variable amount of air into the engine on deceleration to clean up emissions and avoid dieing. Adding unmetered air may cause strange leaning effects. That said, I see no reason why you couldn't play with the air flow through the EEC Tuner to control the over leaning condition.
Chris
Chris98vobra
98 Tan on Laser Red Rag Top Cobra
Fully built and forged with Mahle pistons, SHM Blower cams, ported heads/nitrated valves
Novi 2000, 52# RC injectors, custom IC, Devilsown alky injection, SSR Intake, Steeda rails and -8 feed lines, 03 tank + Aviator dual pumps
Tuned with SCT Pro Racer Package (and everything else over the years)
Lot's of other stuff!
Chris98vobra is offline
post #6 of 7 Old 05-06-2002, 02:37 PM Thread Starter
Jeez, could have sworn you had one hanging off that thing. Oh well, I'm going to try ripping all that stuff out of there eventually.
BTW, do you have those little air filters on both valve covers or just the drivers side?
-Ed
post #7 of 7 Old 05-06-2002, 03:01 PM
I have one filter, but it ties into a Y that goes to both valve covers. I plugged the PVC inlet to the plenum so it isn't hooked up anymore.
Chris
Chris98vobra
