PI Head Swap Reliability... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-05-2002, 10:59 PM Thread Starter
Question PI Head Swap Reliability...
Well I have finally got myself a set of PI heads for my stang, and I must say that I am really excited about it. I will get them ported and polished before they go on the car. My question is quite simple; will I be able to get 100,000 miles out of a PI head swapped 98GT? Will the increase in compression cause any long term effects? I really need this car to last me a long time. I have 40,000 miles on the clock now, so will I be able to see 150,000 miles with the PI head swap? Thanks...
'98 GT
Boss330 Racing 2V
ModularMisfits.com
Madi98GT is offline
post #2 of 6 Old 05-06-2002, 02:43 AM
US Air Force Active Duty
Patrick98GT's Avatar
Thumbs up
As long as the heads are installed correctly--
The only problem you should see is white smoke coming from the wheel wells.
-Pat
'98 Mustang GT -- Novi'd & Usually Needs FixT
Ford F150 sCrew -- Mall Crawler, Family Hauler
Patrick98GT is offline
post #3 of 6 Old 05-06-2002, 03:11 AM
Chris98gt's Avatar
no problems here for over 10,000 miles
-Chris
2004 Subaru WRX
245HP/235TQ
///AWD
Chris98gt is offline
post #4 of 6 Old 05-06-2002, 08:10 AM
Yeah, I think you've chosen, like many of us, the least likely way to cause harm to your engine, while significantly boosting HP. Like was said above, with a good install, and with all the "normal" maintenance, oil changes, etc., you should be good to go. I've had mine in for about 6mos now, and no problems whatsoever.
bierbelly is offline
post #5 of 6 Old 05-06-2002, 10:30 AM Thread Starter
thanks for the replies guys, anyone else want to chime in?
'98 GT
Boss330 Racing 2V
ModularMisfits.com
Madi98GT is offline
post #6 of 6 Old 05-06-2002, 01:56 PM Thread Starter
'98 GT
Boss330 Racing 2V
ModularMisfits.com
Madi98GT is offline
