HELP!!! ELECTRICAL PROBS - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-05-2002, 06:18 PM Thread Starter
Exclamation HELP!!! ELECTRICAL PROBS
Help Guys....Ive got a 98 Cobra...Car keeps burning out the Fuel Pump fuse. Gone thru like 3. Cars getting towed home right now. If anyone has any info on what the prob might be please post ASAP! Need car by tonight! Thanks!!!
98VenemouSnake is offline
post #2 of 6 Old 05-05-2002, 07:31 PM Thread Starter
Im thinking my fuel pump went to ****s....But would this cause for the burned out fuses? Please help....
post #3 of 6 Old 05-05-2002, 07:35 PM
Yes, when I owned a '98 my fuel pump went bad & this is exactly the same thing that happened to me (popped the big fuse out in the power dist. box under the hood). Replaced the first time & it was fine for a short drive & then it blew again. Change the pump - no more problems.
This is in the tank, so try to run the gas out of the car as much as you can if possible. Otherwise you can syphon it off or just man-handle the tank full of gas. Good luck.
-Ed
Ed Hubbard is offline
post #4 of 6 Old 05-05-2002, 08:47 PM Thread Starter
Cool deal thanks Ed. I was pretty sure it was the Fuel Pump. Gives me a reason to upgrade. Called Brothers Performance but turns out theyre out of the 255lph fuel pumps. Guess I have to wait a bit. Sucks not having a car.
post #5 of 6 Old 05-05-2002, 11:04 PM
Get one from Houston Performance. They do a lot of 4.6 work & are good at shipping stuff...
http://www.houstonperformance.com/
-Ed
post #6 of 6 Old 05-07-2002, 12:20 AM
Is the 98 fuel pump specific for the 98 only or is it the same as the gts for 96-97. I know the 98 Gts have the return less fuel system???????
SvtFiveOH is offline
