just installed cams, have ?s - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-04-2002, 05:25 PM Thread Starter
Question just installed cams, have ?s
i just installed my fixed crane 550/217 cams and have a few questions. first, i did a compression test, and am now showing between 200-215 psi in all cylinders. is this allright? second, the car is not idleing well(very lopey, and i was told these were not lopey cams). should i reset the pcm. i took it for a test drive after breaking the cams in and noticed that each time i got on it it felt a little stronger, like the comp was adjusting for them. any ideas?
DD: 2004 Grand Cherokee Freedom Edition with 4.7 HO V8
Auto-x slut: 1999 Miata setup for street prepared
Wanted: Fun V8 musclecar!
96gtmustang is offline
post #2 of 4 Old 05-04-2002, 05:39 PM
you really need to reset the comp.. take the battery cable off for a while.. this helps the comp. to learn everything faster then driving it around to break it in
majorbta is offline
post #3 of 4 Old 05-04-2002, 06:21 PM
US Air Force Active Duty
Patrick98GT's Avatar
All cylinders @ 200-215 is just fine.
I'd reset the computer and try again, it should run better.
-Pat
'98 Mustang GT -- Novi'd & Usually Needs FixT
Ford F150 sCrew -- Mall Crawler, Family Hauler
Patrick98GT is offline
post #4 of 4 Old 05-05-2002, 08:51 AM Thread Starter
thanks, i'll reset it today
