NE1 using AJE tubular front end with Fox body A-Arms?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 05-04-2002, 11:11 AM Thread Starter
I read an article about it in MM&FF where Ken Miele fitted his tubular K with the older Fox A-arms to bring the front runners inside the fender more. He simply swapped ball joints between the two pieces to be able to run the newer stock spindles and brakes that are on his car. I have a 94 (I know 5.0) but the body style is the same and nobody in the 94-95 forum even has an AJE setup like I want so I posted here. Has anyone tried this on their car?? any ill effects as a result?? My car is going to be a drag only piece so handling and cornering is not an issue. Also, I want to run a Flaming River manual rack but will I need to set the tie rods to the fox length with the converted arms for it to be right?? Any help with this would be appreciated. Thanks
Paul
showstopper2 is offline
