Why is it cheaper to forge a motor before you blow it up? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 05-03-2002, 10:23 AM Thread Starter
I keep hearing/seeing that it's cheaper to forge a motor the first time instead of after something bad happens. Why is this? You still have to replace all the internals, gaskets, and bolts, so how do you come out ahead? What would it cost if I were to build my block now vs building after I popped a piston or rod? Thanks in advance.
2012 Silver GT, M6, Brembos, 3.73s, Lethal OR-H, K&N, tuned
Marc00GT is offline
post #2 of 12 Old 05-03-2002, 10:37 AM
indy2000's Avatar
I don't think 4.6 rods, crank and/or block are cheap replacement parts and all can be affected in a catastrophic failure.
indy2000 is offline
post #3 of 12 Old 05-03-2002, 10:44 AM
I would assume if you grenade a piston and chunks of it start beating your heads to death their going to hit your wallet hard. Also if you throw a rod and it goes thru the block.. Well.. That wouldn't be cheap to replace either..
I still don't think you'll have an absolute guarantee you won't harm the motor even if it's forged. Lot of people just shoot for a very safe tune and run the stock bottom end. When it goes just pay to rebuild it at that time..
BeFast is offline
post #4 of 12 Old 05-03-2002, 11:03 AM
Fast Eddie 2k1 GT's Avatar
well, you could sell the short block and then get a SHM short block. At least your getting something for the engine. If its damaged then you can't sell it for very much if at all.
Fast Eddie 2k1 GT is offline
post #5 of 12 Old 05-03-2002, 11:17 AM
There is alot of labor involved when the machinist has to port and polish the heads. It is done by hand and is time consuming. That's all I can think of.
Pete361 is offline
post #6 of 12 Old 05-03-2002, 11:33 AM
mchafin's Avatar
If you put a rod through the side of the block you'll have to buy a new block. Also if you end up buying a SHM block you'll have to give them back a good core or you'll pay a hefty fee..
Mike
1997 Viper GTS
1996 Cobra Superchaged
1995 SVT Lightning
1995 Saleen S351R
1989 Mustang GT
1987 Mustang Coupe
1986 Mustang SVO
1986 Mustang Coupe
http://www.chafin.net
mchafin is offline
post #7 of 12 Old 05-03-2002, 12:11 PM
Mainly...If you wait for failure, you could destroy the whole engine. Or if the stock oil pump gears go, all the bearings seize, need complete short block probably.
However, another reason is the value of time. I've noticed when people blow, they are usually down a long time (months), as it came unexpected and not planned for.
If you rebuild or buy an engine before you need it, you can operate on your schedule, and for sure have a core to trade back in if you buy an engine.
8
Ralph Greene
Ralph Greene is offline
post #8 of 12 Old 05-03-2002, 12:17 PM
mchafin,
OMG YOu actually own 8 Cars???????????????
BeFast is offline
post #9 of 12 Old 05-03-2002, 12:44 PM Thread Starter
I agree with this. Anyone have ideas on what I could sell a GT motor for? Just the short block or the complete motor?
Marc00GT is offline
post #10 of 12 Old 05-03-2002, 12:46 PM
Blown284's Avatar
Trader Feedback: (21)
Re: Why is it cheaper to forge a motor before you blow it up?
When mine blew, it wasn't "just a rod or piston"..... 99% of the cylinder wall was literally blown away ..........rendering the block totally useless.
I guess if you're looking at it in that type of way, the stock crank is still good although everything else is toast.
Hope that helps.
Tim
SOHC/DOHC Corral Moderator
Founder,
Part-Owner,
and
'00 Ford F-350 7.3 Turdbo Diesel
'03 Droptop Cobra
'99 Cobra "10 Second Street car" (SOLD!)
Blown GT ([email protected]) ---> SOLD
'00 Camaro (Couple of bolt-ons) - [email protected] (Jun 2011).
AOL: Blown284
Blown284 is offline
post #11 of 12 Old 05-03-2002, 01:28 PM
Exclamation
Marc00GT,
This should answer your question:
http://www.jdmengineeringinc.com/id159.htm
NakMan
1996 Cobra Coupe, #7312/7496 black/black
- 522hp/442ft lb (DynoJet 424xLC2)
2001 F-150 Lightning, #1856/6381, red
- 375hp/443ft lb (DynoJet)
NakMan is offline
post #12 of 12 Old 05-03-2002, 05:15 PM
Originally posted by NakMan
Marc00GT,
NakMan
That's very interesting. good post
Pete361 is offline
