Getting my LT's put in Monday at Lone Star Performance..... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-03-2002, 03:27 AM Thread Starter
G98Cobra's Avatar
Cool Getting my LT's put in Monday at Lone Star Performance.....
Anything I should be looking foward too, got the O2 extensions, LT's, shorty catted H-pipe. Gonna have them install a new clutch also since they will have it all apart anyways, got a SPEC stage II + their aluminum flywheel!
Will I have any problems driving it, I hear of people saying their car dies under certain conditions.
And should I get a chip burned soon, got some mods on there now and just wondering.....
Thanks!
98 Black Cobra
4.10's
K&N Filter
BBK LT's
BBK O/R H-pipe
PRO-M 87mm MAF
Magnapack Catback
Steeda Underdrive Pullies
SPEC Stage II Clutch
SPEC Aluminum Flywheel
SPEC Pressure Plate
JMS Custom Tune Chip (Chris Johnson Tune)
293.7 hp
288.8 trq
G98Cobra is offline
post #2 of 6 Old 05-03-2002, 04:41 AM
2cammer97's Avatar
excellent decision on the longtubes, they will work great on your cobra. i would go ahead and add the steeda pullies before you add a dyntuned chip. and with the chip you don't need to get a timing adjuster since they add timing with the chip. post up dyno numbers after the lt's are installed.
marcus
'99 Jeep Wrangler Sport 4.0L - offroad toy
2cammer97 is offline
post #3 of 6 Old 05-03-2002, 04:45 AM Thread Starter
G98Cobra's Avatar
Cool
Actually 2cammer, I already have the pullies installed, got them 4.10's, and an aluminum driveshaft installed a few weeks ago!
Will definately get some dyno numbers when this is all put on, can't wait!
Are you saying I will not need a TA if I get chipped? I got a TA, hopefully to be put on soon, is it a waste?
98 Black Cobra
4.10's
K&N Filter
BBK LT's
BBK O/R H-pipe
PRO-M 87mm MAF
Magnapack Catback
SPEC Pressure Plate
293.7 hp
288.8 trq
G98Cobra is offline
post #4 of 6 Old 05-03-2002, 04:50 AM
2cammer97's Avatar
the TA is a waste if you want a dyno tuned chip. if you put the TA on and adjust timing to optimal and your A/F ratio is good then you won't really need a tuned chip since these are the main two areas a chip focuses on, timing and A/F. i have more mods then you on my car but the dyno tuned chip was worth 20 rwhp and 16 rwtq. how was your A/F on your previous dyno pulls?
marcus
post #5 of 6 Old 05-03-2002, 05:00 AM Thread Starter
G98Cobra's Avatar
Don't know the A/F, some guy in an import, with a huge ass muffler, 2 cars ahead of me somehow damaged it so it would not read properly, hopefully the next time I go back it will be working properly!
So basically, it's either a TA or a dyno chip? Can't have both and benefit from both being on at the same time?
98 Black Cobra
4.10's
K&N Filter
BBK LT's
BBK O/R H-pipe
PRO-M 87mm MAF
Magnapack Catback
SPEC Pressure Plate
293.7 hp
288.8 trq
G98Cobra is offline
post #6 of 6 Old 05-03-2002, 05:11 AM
2cammer97's Avatar
there is really no benefit of having a TA and a chip at the same time. most people that have TA's that later on feel the need for a dynotuned chip end up selling the TA (that's what i did as well). the TA worked great when my car was mostly stock but as soon as the heads/cams/longtubes/etc went on the TA came off and in went the chip. i would wait to put the TA on until after you dyno and make sure to get an A/F done. if the A/F looks good (12.5 to 13.2) then i would slap on the TA and adjust the timing on the dyno again and you should not need a chip. if you get dynoed and your A/F is rich at like sub 12 then i would sell the TA before even putting it on and just go straight to getting a tuned chip. i would recommend Houston Performance although it is a little bit of a drive. they are awesome and steve knows his stuff. hope this helps.
marcus
