-3.2* Camber.... Where is the cheapest place for MM C/C plates?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-02-2002, 06:24 PM Thread Starter
blue88mustang's Avatar
Exclamation -3.2* Camber.... Where is the cheapest place for MM C/C plates??
Unless you guys can prove to me that there is no difference between the Pro3i plates and the MM plates, I am going with the MM plates.
With that in mind, where is the cheapest place for the MM plates?
Thanks in advance... as seen in the title, I have waaayyy too much camber and I need to fix this before I can go to the track about 50 miles away from home.
88 LX 5.0 Vert
blue88mustang is offline
post #2 of 9 Old 05-02-2002, 06:42 PM
Re: -3.2* Camber.... Where is the cheapest place for MM C/C plates??
I was quoted at $179 from www.houstonperformance.com
erick-b is offline
post #3 of 9 Old 05-03-2002, 12:25 AM Thread Starter
Thanks, but I ordered some from Craig at ModernPerformanceNW for $185 shipped. He is closer to where I live than houston is, and he was 1hr behind me so that meant I got my order in today. Hopefully the install goes pretty smoothly.
Thanks.
88 LX 5.0 Vert
post #4 of 9 Old 05-03-2002, 01:23 AM
from what i have heard... you can only adjust your caster/camber from 1 degree one way or the other with C/C plates.. i may be wrong.. but that is what most places say anyhow.. may want to look into that good luck
badest02GT is offline
post #5 of 9 Old 05-03-2002, 02:12 AM
Authorized Advertiser
Black96Cobra's Avatar
Not true, you can get quite a bit of adjustment with aftermarket plates. He'll be able to get that back to where it belongs with the MM plates.
-Craig
1-866-693-4441
Paxton, ATI, Maximum Motorsports, SPEC Clutches, AJE, JBA, C&L and more...
Black96Cobra is offline
post #6 of 9 Old 05-03-2002, 09:21 AM
you're right black96cobra--
you can typically get about 3 degrees of camber adjustment either way with plate. I have the hotchkis, was running -2.5 on one side after the springs, and alignment guy had no problem getting it to -0.7
nighttrain is offline
post #7 of 9 Old 05-03-2002, 09:57 AM
Fast96SVT's Avatar
I don't know about MM PLates but I got my Ground Punders from Laurel Mountain Mustang.com for $135 + $10 shipping. I got the front end aligned the next day with skinies on and he said it was the best alignment that my car has had! And he has aligned it 3 times this being the 4th. Still going strait today!!!
Blue and Copper 04 F150 Screw -The Daily Beater
White 96 Cobra #705 out of 7496 -Way to much to list! 850HP coming soon...
Red 93 5.0 - Pretty stock "Thank You DAD!"
Fast96SVT is offline
post #8 of 9 Old 05-03-2002, 12:55 PM Thread Starter
I went ahead and ordered a set from Craig(Black96Cobra) and hopefully my friend and I will install them next Thursday night. Look for a "Need Tips on MM C/C Plate Install" thread.
Thanks again Craig... I will be looking for some AJE stuff in the future.
88 LX 5.0 Vert
post #9 of 9 Old 05-03-2002, 05:33 PM
Fast96SVT's Avatar
Installation isn't hard at all. Just put all the bushings in there proper places unbolt the stock ones, pul them off, slide the new ones back on and bolt them down. Don't forget to put the brass loooking or what ever color plate it is under the wheel well. CC plate on top that plate on bottom. bolt down and have it aligned
