Anderson Ford NA Power Pipe ??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 05-01-2002, 10:26 PM Thread Starter
Question Anderson Ford NA Power Pipe ???
Anyone outthere running an Anderson Ford NA power pipe on a DOHC. I was thinking of making that my next purchase. Let me know if its worth it or not.
19Black_Venom97 is offline
post #2 of 23 Old 05-01-2002, 10:29 PM
SLOWBRA's Avatar
I just got mine, I should have it on in a few weeks along with some dyno #s...
It's a nice quality piece, I love the coating and it looks damn good under the hood.
Shawn
2004 Comp Orange Cobra Vert
1995 Cobra R
2003 Shamu Harley Davidson F150
"Run what you brung & hope you've brung enough"
SLOWBRA is offline
post #3 of 23 Old 05-02-2002, 01:17 AM
A friend of mine with a 98 Cobra was running one until he went blown. He dynoed after he installed it and it was worth 8 RWHP on his car N/A. Hope that helps.
96 Ford Cobra, PHP Stage 2 intake, All the bolt-on's, SVO Ceramic Headers, Bassani Off-Road X-pipe, Borla XR-1's, and The New 4.56's are in!
95 ZX9R Ninja 136RWHP/ 70RWTQ [email protected]
06 2WD TrailBlazer SS 6.0L LS2 395HP Stock
ALLNTRL is offline
post #4 of 23 Old 05-02-2002, 08:36 AM
bow tie klr's Avatar
I have had mine for over a year now and love it. I havent ever dynoed it, but I need to. It is a very nice piece. I track test alot of stuff so. I was running aprox 13.5-6 at 104-5's after the PP I was running 13.3-4 at 106.5's with a best of 107. The days were a week apart and that is over an average. It really pulls up top!
97 White Cobra Coupe -- blower sold. turbo build in progress.
ported 04 heads, Al's ported 01 intake, 9.5 comp forged studded 5.0L stroker AL shortblock, comp cams, big A/A intercooler and Th400
bow tie klr is offline
post #5 of 23 Old 05-02-2002, 10:44 AM
281cobra's Avatar
Can it be used with the stock Mass air unit?
281cobra is offline
post #6 of 23 Old 05-02-2002, 12:29 PM
Yes you can. I havent gotten around to investing 250 Bucks on a New MAF for 19lb Injectors...
I love the way it works Got an extra 1.5mph and 1 Tenth in the 1/4
2000 Performance Red GT
01 COBRA MOTOR w/Aftercooled V2 SQ w/Gt Impeller
521RWHP and 419TQ on a Mustang Dyno
Up Next: T-Trim and Smaller Pullie
ac1122 is offline
post #7 of 23 Old 05-02-2002, 12:45 PM
docdave22's Avatar
Trader Feedback: (18)
Man, that piece sounds really promising.
Why haven't I heard of it before? With numbers like that, you think that it would be a big buzz around here.
I'm guessing that it will not fit under the strut tower brace.
2012 5.0 with TVS2300
docdave22 is offline
post #8 of 23 Old 05-02-2002, 01:09 PM
Most people stay away from it because its 100 Bucks more expensive than any other CAI...
I dont have a STB and I dont believe that any will fit over it...Maybe for the Cobra's they will but Definately not for the GT's.
My favorite thing about it is when me and my buddies drive our stangs around and Then stop and pop the hoods you touch their so called CAI's (MAC BBK) and you'll fry your hand on them...Touch mine and its cool as Hell...Less heat More Power!!!
ac1122 is offline
post #9 of 23 Old 05-02-2002, 01:27 PM
KCCobra's Avatar
Sounds pretty good to me... did you have to remove your strut tower brace? I went to your site and saw you had it on there with the stock air intake.
Are you running the suggested C&L Mass air meter? What air filter?
Thanks,
2004 Cadillac CTS-V, LS6/6-speed, all stock.
KCCobra is offline
post #10 of 23 Old 05-02-2002, 02:09 PM
Yea I had to remove my STB. I wasnt too happy about that but oh well. I was told befor I purchased it that it would fit with the STB but after adjusting and readjusting everything several times I just said screww it and left it off. I really like it. You can use the stock meter or a C&L or a pro-m. I went with the pro-m because I already had it. Works great. Will work fine with the stock unit also.
Yea the pic on my web page are old. I am building a new web site and hopefully have it up soon with some pics of it.
I got mine through http://www.nothingbutperformance.com/Parts.asp during a GP. They had a power stack filter that would fit my pro -m so I got it too. Not sure what name brand but it works great.
Hope that helps.
post #11 of 23 Old 05-02-2002, 02:20 PM
I thought the AFM piece was metal as well. That's why some people were staying away from it and going with something like the densecharger instead because it was plastic. Why won't the AFM piece heat up the same as the MAC or BBK?
MustangCobra99 is offline
post #12 of 23 Old 05-02-2002, 02:57 PM
Mine gets warm. I don't know why mine would be any different than yours. They are both GT pipes.
Calvert2812V is offline
post #13 of 23 Old 05-02-2002, 04:53 PM
Warm it does get but Not scorching Hot like the Mac and BBK CAI's do...
And the AFM PowerPipe is It's also ceramic coated so it doesn't get heat soaked like Mac and BBK intake tubes do (which over rides the benefits of having the air coming in from the fender).
Overall I like it.
ac1122 is offline
post #14 of 23 Old 05-02-2002, 09:25 PM
The UPR powerpipe WILL clear under the factory STB and will give the same power gains as the AFM. It isn't ceramic coated like the AFM but, it is not as much $$$ either. Both UPR and AFM use S&B power filters. Hope that helps.
ALLNTRL is offline
post #15 of 23 Old 05-02-2002, 09:45 PM
I've got the Anderson pipe on mine and seems to work pretty well.
HIPSI is offline
post #16 of 23 Old 05-07-2002, 10:11 AM
Slithering_Joe's Avatar
Do you guys ever think that the reason the metal pipe isn't hot after driving is because the air rushing through it cooled it down and the heat was injested by the engine? It heats up the most when the car is stationary or at idle. The best setup would be plastic but personally I think the Densecharger looks like toilet plumbing!!!! I would really like to get the Anderson Power Pipe if it would only clear the strut tower brace. That pinch in the stock tube up by the throttle body has to be a restriction along with the "bumpy" ride from the air filter all the way up to the throttle body.
I would really like to get a cold-air kit the relocates the air filter and MAF sensor to the inner fender outside the engine compartment for my 96 Cobra.
There was another company that made a Cold-Air Induction (CAI) kit. I think they called theirs a "Power-Tube." I believe the company was/is called "PPT" but I can't find anything about them. Someone here a long time ago introduced them to me. Is there another company besides the ones mention here (Anderson, BBK, UPR, C&I, MAC,
) that I may have overlooked make a CAI for the 96-98 Cobras?
2005 Cadillac CTS-V
- '96 Cobra 13.45 at 104.458 mph
- '89 GT
- '94 GT Convertible 13.905 at 100.41 mph
Slithering_Joe is offline
post #17 of 23 Old 05-07-2002, 12:49 PM
WMS Velocity Tube-ceramic coated,silver or black.
www.wmsracing.com
Hiss01 is offline
post #18 of 23 Old 05-07-2002, 01:48 PM
My AFM pipe can with a K&N filter.
Slithering_Joe... You could always make your own inlet setup and save some $$ for the time being. You'd have to use the "toliet plumbing" from Lowe's or wherever is good for you, and you could always paint it, and it could serve the purpose for the time being.
post #19 of 23 Old 05-07-2002, 07:09 PM
Try www.volantperformance.com They make some induction kits for the GT's, not sure if make one for the Cobra or not.
96stang99, If your filter has the funnel filter part in the front of the air filter then it is an S&B not a K&N. They are made from the exact same stuff, just the K&N doesn't have the extra funnel filter in the front like the S&B's.
ALLNTRL is offline
post #20 of 23 Old 05-08-2002, 12:58 AM
Well, its been a while since I've seen my air filter, as its down in the fenderwell... but, mine has the "chrome cap" on it with the K&N logo on it, so I just figured it was a K&N. It'll be out when the intake and cams go in, so I should know FOR SURE then.
post #21 of 23 Old 05-08-2002, 09:50 AM
For the time being I'll just leave the stock setup in. I think the toilet stuff looks like a$$ !!!! ...especially painted. I want a clean installation.
2005 Cadillac CTS-V
- '89 GT
post #22 of 23 Old 05-08-2002, 10:31 AM
I can't seem to make up my mind on this....
either densecharger or AFM powerpipe......
I have MAC cold air and would like to get one that goes all the way to the throttle body.
KeithCobraUH is offline
post #23 of 23 Old 05-08-2002, 01:57 PM
Personally, I think it looks like crap.
There has to be a cleaner installation than above somewhere out there.
2005 Cadillac CTS-V
- '89 GT
