question about detonation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-01-2002, 12:15 PM Thread Starter
sapperstang78's Avatar
im almost positive my car is pinging. i had it in for a tranny problem and the dealer informed me it was pinging too. my only problem is im not sure what it sounds like. the sound i hear is when im idling with the windows down i hear what sounds like sand being poured through a metal pipe or something. if i put it in neutral whenidling and rev it slowly this sound gets louder as if there is now rocks mixed in with that sand. also ihear it really well if i have the o/d on and am going about 40 mph uphill. i refuse to use 93 ocatane since these vehicles are supposed to run on 87.....whats everyone think?
Originally Posted by Dave88LX View Post
Hell yeah! I can't wait to start sucking some cocks!!!
sapperstang78 is offline
post #2 of 8 Old 05-01-2002, 01:33 PM
what do i think? use 93. period.
b1nyc is offline
post #3 of 8 Old 05-01-2002, 04:12 PM Thread Starter
yeah but like i said, i shouldnt have to spend the extra money on 93.....the car is supposed to run fine on regular unleaded. and i did put a half tank of 93 in to see if it would work. it still makes the sound
post #4 of 8 Old 05-01-2002, 05:16 PM
97GTConvt's Avatar
Hope you have your warranty still. Could be as easy as a fouled MAF, or as bad as low compression. Sorry to hear about it but definitely get it checked out ASAP as things will only go downhill quickly if you leave it like that.
Lon
97GTConvt is offline
post #5 of 8 Old 05-10-2002, 04:52 AM
dantheman98id's Avatar
pinging
My 96GT used to ping all the time, then I went for the first solution and ran the high octane in it for 3 months. Went back to 87 and it hasn't come back. Hope this helps.
Dan
1996 Rio Red Mustang GT 5-speed
Mobil 1 15w-50, Havoline 5year, Distilled Water
K&N Oil Filter, K&N Air Filter
Bridgestone Potenza RE730 up front Nitto Dr's out back
1986 Ford F-150 Lariat 5.0L EFI Auto
dantheman98id is offline
post #6 of 8 Old 05-10-2002, 06:41 AM
I have never heard of a car pinging at idle. Most if not all cars that are pinging will do so under load. Are you sure you are not hearing a bad idler pulley bearing or something ? Try taking your belt off and start it for a min to see if the sound is still there.
Dwayne
46GTSblown is offline
post #7 of 8 Old 05-10-2002, 08:00 AM
Yep, it won't "ping" (detonate) at idle, or at low load. You need to be close to WOT for that. You are hearing something else. Pinging sounds like a diesel engine.
David Posea is offline
post #8 of 8 Old 05-10-2002, 05:18 PM
97GTConvt's Avatar
Sounds like you have an exhaust leak. They're the most common thing when peeps think their engine is pinging, even happened to me. Do you hear it more next to a building or going over a bridge? Turn the car on then get under with a piece of rubber hose and listen through it and point it at and again where your headers meet your h-pipe, then work your way back up to the engine. You'll find the culprit in no time.
Lon
1997 Autumn Orange Mustang GT Convertible(1 of 1,519 produced) - SOLD
2003 Torch Red Mustang SVT Cobra Convertible - FOR SALE
