Question about keeping a blown car cool in the summer heat - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-30-2002, 04:24 PM Thread Starter
austinTX's Avatar
What will do more to keep the engine cool an inercooler or a larger radiator? and why?
2002 YZF-R1 12:00 Wheelies
1999 Cobra
AFS Cobra Rs Front 17x9 on 255/45 Back 17x10.5 on 285/40 R17's.
Tweecer RT
DS clutch peddle lowering device
Steeda Triax.
Kenny Brown Sports package
Bilstein Shocks\Struts (Cobra R)
K&N airfilter.
FRPP aluminum drive shaft (4602-J)
SPEC stage II clutch
Alumimum fly wheel
Steeda Tri-ax
Novi 1000 (not currently on the car)
13.51 @ 103.2 mph N/A
New Mods
2001 Head/Block due to water damage ---- (engine died 1 month later, oil pump failed)
1999 Long block from Ford now installed. (putting blower back on in about 6 months)
austinTX is offline
post #2 of 5 Old 04-30-2002, 04:45 PM
onerichrunner
Guest
Posts: n/a
Both.
post #3 of 5 Old 04-30-2002, 05:16 PM Thread Starter
austinTX's Avatar
Not sure if they will both fit with out some modification. Which one would help the most. I can do one or the other by myself but when it comes to custom fabrication well that's a diffrent story.
1999 Cobra
Tweecer RT
Steeda Triax.
K&N airfilter.
Alumimum fly wheel
Steeda Tri-ax
New Mods
austinTX is offline
post #4 of 5 Old 04-30-2002, 05:52 PM
onerichrunner
Guest
Posts: n/a
get the Steeda radiator and you can make the rest fit. 4.6Cobra is running an IC with the Steeda & Novi 2000.
post #5 of 5 Old 04-30-2002, 05:58 PM
You'll also need to kick your cooling fan on sooner to take full advantage of the bigger radiator.
Blown46Cobra is offline
