Knocking noise in tranny - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-29-2002, 12:14 AM Thread Starter
Question Knocking noise in tranny
I recently replaced the clutch, pressure plate, throw out bearing, and pilot bearing in my 96 GT, but now have a rattling noise ( at idle is when I notice it the most) when I am not pushing in on the clutch pedal. If I push in the clutch pedal the noise stops. I think it is the release lever tapping against the bell housing. I do not think this is normal, at least I don't remeber hearing this noise. I also noticed right after the replacement that the clutch will engage as soon as I ease off the pedal, as before the pedal would travel half way up before the clutch would start to engage. It seems like when I attached the cable back to the lever it went on easier then when it came off. Please help me so I can resolve these issues.
MRH
mrh96 is offline
post #2 of 4 Old 04-29-2002, 12:55 AM
It sounds like you are hearing neutral roll over> I recently replaced my tranny to a T-56> and started to hear the same thing> D+D transmissions said that it was normal because you put in an aftermarked clutch that will also tend to make it a little louder. They explained that the stock clutched are tuned to be quiet and the a/m clutched are not always all that quiet.
hope this helps
WIKD 281 is offline
post #3 of 4 Old 04-29-2002, 03:08 AM
96BluOvl's Avatar
Sound like chatter to me. My stock clutch does that. and its either the throwout bearing is bad or the disc is bad. You got a bad clutch IMO.
96BluOvl is offline
post #4 of 4 Old 04-29-2002, 09:23 AM
Sounds to me that you might want to look at clutch adjustment. I do not think it is normal for a clutch to release that close to the floor. My clutch also releases/engages at about half pedal travel.
Dwayne
46GTSblown is offline
