255 lph fuel pump. High pressure or no? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-28-2002, 08:48 PM Thread Starter
Pottus's Avatar
I recently ordered a BBK 255 lph fuel pump since Ill be running 2001 heads and a 125 shot of "NAWS" and I noticed that with some brands there is a regular 255 lph and a high pressure lph. I ordered part number 1607. Will this be okay or do I need to get something like the walbro high pressure 255 lph?
2006 Tungsten Grey GT Convertible
3.55s / Hurst Shifter / Strut tower brace / FRPP X pipe / FRPP GTA axle back / FRPP CAI / FRPP 91 octane tune / Vogtland Springs / Koni STR.T shocks/struts / Sequential tails
Pottus is offline
post #2 of 9 Old 04-28-2002, 08:51 PM
I have never heard of dif types of 255 pumps but I was told that the 190 pumps run a higher presure but less volume than the 255pumps.
hsram is offline
post #3 of 9 Old 04-28-2002, 09:25 PM Thread Starter
Pottus's Avatar
Forgive my igrnorance on the subject but which would I need? I just went with 255 because it seems like thats what everyone runs on a N2O application. I figured it must be the best choice.
Pottus is offline
post #4 of 9 Old 04-28-2002, 10:35 PM
the walbro gss342 255lph "hi-press" pump is what you should use to run you 125-shot.
11 KB GT at 15psi
11 CTSV
12 F350
11 Z71
stroked or blown? is offline
post #5 of 9 Old 04-28-2002, 10:40 PM Thread Starter
Pottus's Avatar
Thanks! Ill cancel my BBK since its on backorder and get the walbro.
Pottus is offline
post #6 of 9 Old 04-29-2002, 12:44 AM Thread Starter
Pottus's Avatar
One more question. Any suggestions on where to get it?
Pottus is offline
post #7 of 9 Old 04-29-2002, 12:54 AM
Get the High Pressure pump. It can support to 90PSI.
Get it at: www.musclemotors.com
Eric
Stedda is offline
post #8 of 9 Old 04-29-2002, 01:06 AM
Try www.jdsperformance.com
Nothing but good service from Dave
1997 COBRA CONVERTIBLE
BBK L/T HEADERS
O/R SHORTY H-PIPE
2 CHAMBER FLOWS
ASP PULLIES
C & L Mass Air Meter w/K& N Filter
Canton 7 Qt Street Pan w/ Windage Tray
D & D K-Member Kit w/Coil Overs
Maximum Motorsports C/C Plates
HPM Upper & Lower C/A's
Stange 10 way Shocks & Struts
Aluminum D/S
Moser 31 Spline Axles, 4.30's, everything welded
FordChip Dyno Tune 9-13-02
291.8 hp
285.9 tq
Best E.T [email protected] 106.31 mph w/ 1.74 60'
MD COBRA is offline
post #9 of 9 Old 04-29-2002, 09:44 AM
Post
Most likely, BBK just sells a Walbro with their logo on it. That is was Holley and most other companies do anyway...
RFGreen96GT is offline
