white smoke from exaust? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-28-2002, 11:00 AM Thread Starter
Question white smoke from exaust?
I installed 42# injectors, 80mm mass air, 97 fuel rails, and an aeromotive f/p regulator. It idles fine at startup, and f/p is at 45psi. I drove it around for a few seconds, and it kept stalling every time i would stop, a big puff of white smoke from the exaust followed. It looks like the f/p goes down when driving it? The 10:1 FMU is still on there because I need to get a new line to bypass it. Could that have anything to do with it? I know i need to have it tuned, but shouldnt I be able to drive it without it stalling at every light? Should i go to Diablo for the tune?
Parts not in sig.
Walbro 255lph intank (gss307)
Walbro 255lph inline ( ? )
xxdrubloodxx is offline
post #2 of 6 Old 04-28-2002, 11:20 AM
I'm not a guru on the '98's, but with the 42#r's and a MAF (assuming it is calibrated right) clocked in the right position, along with the extra fuel pumps, you shouldn't need the FMU at all.
There have been issues with the Pro-M's not being matched right to the injectors.
RUUP2IT is offline
post #3 of 6 Old 04-28-2002, 01:32 PM Thread Starter
what does white smoke mean?
post #4 of 6 Old 04-28-2002, 01:37 PM
SnakeBit's Avatar
It means that the Cardinals have elected a new Pope.
SnakeBit is offline
post #5 of 6 Old 04-28-2002, 01:41 PM
isn't it either you are buring coolant or a blown head gasket?? have you changed the head gasktes recently cause usually after you change them there is a little white smoke from burning a little coolant.. thats ok
majorbta is offline
post #6 of 6 Old 04-28-2002, 03:43 PM
head gasket, warped head, engine block crack
Cobra'03 is offline
Behind the Smoke with Dai Yoshihara - The Series Discount Tire Discount Tire 24 11-03-2011 04:50 PM
White Smoke on Decel 97SVTRed SVT & DOHC 0 03-02-2008 07:27 PM
replaced gaskets, Still white smoke! ngc414 5.0/5.8 Engine Tech 27 07-22-2007 04:27 PM
Mysterious white smoke at normal temp idle dhititright 5.0/5.8 Engine Tech 3 02-25-2004 02:00 PM
White smoke coming from tail-pipes Fastcat 5.0/5.8 Engine Tech 9 04-11-2002 12:37 AM
