Valve Guides-- falling out - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-27-2002, 09:27 PM Thread Starter
RedStallion98's Avatar
I just performed Headswap on my 98 Mustang. Well after 50 miles I began getting this awful banging sound (maybe recal post about installing head gasket wrong I thought that was problem)
Well I took the intake off and 4 of the valve guides have fallen out on the passenger side. My machine guy is going to fix both heads for free replacing them all.
But is this a known problem?
The heads were supposed to only have 12000 miles on them and are off a 2001.
RedStallion98 is offline
post #2 of 5 Old 04-27-2002, 10:45 PM
BTLFED's Avatar
Sounds like maybe the head porter did something, guides dont just fall out even if you have a 100,000 miles.
BTLFED is offline
post #3 of 5 Old 04-28-2002, 12:26 AM
FELL OUT?????? Now that's a new one. I've seen them bent, chipped, cracked, and broken. Never saw them fall out. I'd be checking the heads themselves too. A pressure test would be a good idea.
TheGame is offline
post #4 of 5 Old 04-28-2002, 01:59 AM Thread Starter
Well I have the head off the car now and they are broken. I guess I just had looked at them wrong.
They are broke so yeah I couldnt see how they could just fall out. Thanks for the help
post #5 of 5 Old 04-28-2002, 11:40 AM
I had a tapping coming from my car too. Everyone said exhaust leak. After a lot of guessing we finally found two of the valve guides had gotten loose. Not broken just loose. These are SVO heads though. P&P by houston performance.
Havok is offline
Valve guides needed for Patriot performance heads jmcclesk GT & SOHC 0 10-08-2013 02:04 PM
Worn Valve Guides? - "wiggle test" Video Inside LogDog3D 5.0/5.8 Engine Tech 12 05-30-2012 08:24 PM
dual pvc mods and upper intake oil control larrylass 5.0/5.8 Engine Tech 1 02-01-2009 09:35 AM
What exactly is valve float?/ Anderson ford cam question Qwiketz 5.0/5.8 Engine Tech 9 06-21-2002 12:05 AM
TFS valve guides?? Ticking noise?? MOOVS 5.0/5.8 Engine Tech 6 01-03-2002 05:49 PM
