Semi-solution to 96 Cobra cooling probs - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-27-2002, 02:50 PM Thread Starter
Exclamation Semi-solution to 96 Cobra cooling probs
I went to the track, and was throwing coolant all over just like I always do, and realized that even though my thermostat was just replaced last week, for some reason, it wasn't opening, and this was causing all my problems. So I simply took it out and run the car without a thermostat. It doesn't run hot, right around the "N" now, warm enough to produce heat for the interior, but no more coolant leaks out of the car, and it runs fine. My only problem was that I lost a little bit of trap speed with the thermostat removed, approx. 1mph. And my car has always run better the colder it was. Does anyone know why this would happen? Is it because my oil may not get hot enough, or doesn the engine computer remove timing?
Pat96Cobra is offline
post #2 of 11 Old 04-27-2002, 02:57 PM
Computer doesn't run normal until 170 degrees.
Wickedslobra is offline
post #3 of 11 Old 04-27-2002, 03:20 PM Thread Starter
Ok, does anyone know where on the factory N-O-R-M-A-L gauge 170 degree temp. would read?
post #4 of 11 Old 04-27-2002, 03:40 PM
Re: Semi-solution to 96 Cobra cooling probs
You have a pm.
xs-speed is offline
post #5 of 11 Old 04-27-2002, 03:43 PM
max
Someone earlier checked their gauge and here's the relationship:
N-----185-190
O-----195- 200
R------205-210
M------215-220
A------225-230
L------235-240
max is offline
post #6 of 11 Old 04-27-2002, 04:41 PM
some food for thought.. are you positive the thermostat had been installed correctly? if it was in there backwards it wouldn't see too much hot coolant and would not open or open very little.
BoneDaddy is offline
post #7 of 11 Old 04-27-2002, 04:52 PM
Jim Vaccaro's Avatar
N-O-R-M-A-L
C - 150° (approx.)
[ - 160°
N - 180°
O - 190°
R - 200°
M - 210°
A - 220°
L - 230°
] - 250°
H - 260° (approx.)
Jim V.
2011 GT Auto
11.41 @ 120 MPH
1.63 60ft
Jim Vaccaro is offline
post #8 of 11 Old 04-27-2002, 06:01 PM
max
Jim, you splitting hairs with me?? Are you gonna keep the '96 for the distant future? I'm debating on whether to keep mine.....I'm a little anti-ford right now.
max is offline
post #9 of 11 Old 04-27-2002, 06:15 PM
Max,,not splitting hairs,,just went past your post...
My 96 i am also debateing selling..
I'll have 3 boosted cars and looks like 1 will have to go..
I am never in an anti Ford mode..
good luck with your decision..
Jim V.
2011 GT Auto
11.41 @ 120 MPH
1.63 60ft
post #10 of 11 Old 04-27-2002, 06:31 PM
max
Jim, I'm just in a yanking mood and playing around. Wish I had the time and energy to hang with you northeasterners.....I might learn how to drive and improve my times.
later,
max
max is offline
post #11 of 11 Old 04-28-2002, 09:21 PM Thread Starter
Hmmm, I didn't think you could install one backwards, cause the metal casing it goes inside only seems like it would fit the thermostat one way. I will check and see though, that would be funny if that turned out to be the problem. I am not sure what to do though cause my car, judging by what everyone posted gets to MAYBE 170 degrees coolant temp without the thermostat, and I run it at the track so I need that timing back, especially since I ran a 13.011
I have replaced everything in my cooling system, and removing the t-stat seems to be the only solution so far for me.
1994 - 95 Cobra grille: pony or snake? 1oldfox 94/95 Tech 57 04-19-2013 11:53 PM
For Sale Lots of SN95 GT & Cobra Parts bmwm3 Modular Engine Parts 26 03-26-2012 04:03 PM
Indy Hangout XXXIV - Summer's Over? OneBad93LX Midwest 3501 03-25-2009 12:23 PM
Modular Parts-Tons To Choose From 4V GT Modular Engine Parts 36 06-26-2008 02:46 PM
Back from Iraq, need a CARFAX gr8snk SVT & DOHC 9 04-30-2006 10:38 PM
