Need advice picking guages- please read, thanks - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-27-2002, 12:21 PM Thread Starter
I've ordered Water Temp, and Oil pressure 2 5/8 for the vents in the center dash. For the pillar pod (door) I've ordered the 2 1/16 Boost/Vacume and the Transmission Temp guages.
My car is N/A and will be for awhile.... My question is, should I go with an Oil Temp guage instead of the Boost/vacume? If I go with a supercharger in the future I could then put the fuel pressure and Boost/vacume out on the cowl together ( I was told they should be together).
What help would having the Boost/vacume do for me in my N/A car 'now'..... isn't Oil temp more important? Also, I would have ordered the fuel pressure guage( electric- to keep inside the car without problem ) but there's a recall on that guage
these are all Auto-Meter Phantom guages.
thanks alot
Spenc2u is offline
post #2 of 3 Old 04-27-2002, 07:04 PM
there is a recall on electric f/p guages?
jburson is offline
post #3 of 3 Old 04-27-2002, 08:21 PM
If you're N/A, the boost/vacuum gauge will be of limited usefullnes.
I have an NA GT, and I installed the water temp, oil pressure and oil temp (all mechanical). I would suggest you go with the oil temp, though to warn you, for the most accurate value, the oil temp guage will have to go into the pan, which does require a little work.
-Pete
PeteK is offline
Craigslist removed my dating ad. Available ladies, read inside! stangPlus2Birds Lounge 20 10-14-2013 10:54 PM
Hi, I'd Like Some Advice From You Guys, If Possible! Plz Read. SapperDaddy21B S-197 Mustang GT (2011-2014) 0 11-05-2012 11:58 PM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
Motivated again, need advice, please read ExTrooper 5.0/5.8 Engine Tech 4 01-02-2011 12:59 AM
