Which Shocks??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-27-2002, 10:55 AM Thread Starter
must98gt's Avatar
Which Shocks???
I don't do a whole bunch of road racing, but I would like to upgrade the shocks to some adjustable shocks. I've seen quite a few people with Tokicko's and Koni's, what would be a good buy? I've also heard of many people using Bilstein's, but i don't believe that they are adjustable. Thanks for any input.
1998 Mustang GT
Engine
2001 PI Motor
Dyno Tuned Chip by Coastal Dyno, Tampa, FL
MAC Cold Air Intake
FRPP 70mm Throttle Body
Steeda Underdrive Pulleys
MSD Superconductor Wires
Exhaust
MAC Long Tubes
MAC Shorty Off Road H-Pipe
Flowmaster Cat-Back
Dynomax Polished Tips
Driveline
FRPP Aluminum Driveshaft
Finish Line Performance Stage II Transmission
Centerforce Dual Friction Clutch
Steeda Double Hook Clutch Quadrant
Steeda Tri-Ax Shifter
FRPP 3.73 Ring and Pinion
Hawk Brake Pads
Suspension
H&R Supersport Springs
Tokicko 5-Way Adjustable Shocks/Struts
Steeda Caster Camber Plates
Steeda Tubular Subframe Connectors
Steeda X2 Ball Joints
Best E.T.: 14.062 @ 97.08 1.944 60' (98 Engine)
Dyno: 215 rwhp @ 4600 rpm (98 Engine)
292 ftlbs @ 3900 rpm (98 Engine)
must98gt is offline
post #2 of 4 Old 04-27-2002, 12:12 PM
tirefryr's Avatar
I just went to shox.com and they were very good. Prices for the Tokicos I want are $100 less that anywhere else I've found. And for $80 more, they'll throw in some lowering springs. Just go there, fill out a quote request, and they'll send you the info. Then you can order. They are the cheapest.
'11 GT
'87 Turbo Coupe
'94 F-150
tirefryr is offline
post #3 of 4 Old 04-27-2002, 02:27 PM
I picked up a set of Bilsteins last year at shockwarehouse.com. They work great. Adjustables just seem to be another thing to mess with, and for street driving, I didn't think I'd ever bother with making adjustments anyway. Love the Bilsteins...a world of difference. Now if you make it out to the track on a relatively frequent basis, the adjustables would be more suited.
PhatDoggy is offline
post #4 of 4 Old 04-27-2002, 04:09 PM
Shocks
When I replace mine probably next year I like the looks of Elelbrock IAS shocks and struts. Just my $.02.
2006 Premium GT Convertible
Screaming Yellow, Black Top
Black Leather
18" "Fanblade Wheels"
Interior Upgrade Pkg.
Side Airbags
Soft Boot
Shaker 500 Audio System
5 Speed
CORSA Performance exhaust
GOLDENPONY is offline
New shocks, did I screw up? billyb 94/95 Tech 4 09-12-2007 03:31 PM
stock shocks or multa 1971mustang Drag Racing 0 05-05-2007 01:47 AM
Granatelli Coil Overs w/ Koni Shocks gtrman00 Suspension 5 05-05-2004 09:04 PM
Shocks question, mainly 84 Vs 89? Kevins89notch5.0 General Mustang Tech 5 03-09-2004 12:31 AM
Shocks Shocks Shocks Chingus GT & SOHC 4 02-27-2004 08:09 PM
