Clutch problems, help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-26-2002, 09:31 AM Thread Starter
Clutch problems-help!
My clutch all of a sudden is starting to feel like it's stiff or sticking. Have any of you guys had this problem, and what do I look for to fix it?
could it be low on fluid? It doesn't do it all the time, But it seems to be doing it a little more and more every day. I've never worked on a hydraulic clutch before, so I could use the help.
69MACH/98GT is offline
post #2 of 10 Old 04-26-2002, 12:50 PM Thread Starter
ttt Anyone???
post #3 of 10 Old 04-26-2002, 01:05 PM
duane v's Avatar
Its not hydraulic...If you been running the stock clutch since 1996 its probably time for a new clutch set-up, pressure plate, disk, flywheel and pilot bearing..Very easy to install, very similar to a T-5, Tremec TKO if you have done those ...DA Snake boy!!!
duane v is offline
post #4 of 10 Old 04-26-2002, 01:10 PM Thread Starter
It's a 98 gt... the clutch doesn't seem to be slipping or anything, and the car only has 54k miles on it.
post #5 of 10 Old 04-26-2002, 03:13 PM Thread Starter
TTT
post #6 of 10 Old 04-30-2002, 05:09 PM Thread Starter
ttt Any ideas???
post #7 of 10 Old 04-30-2002, 06:32 PM
Banned
In my opinion if you have the money I would just go with a new clutch. I have 39K on my 98GT and will most likely be getting a new clutch the yr. some time
post #8 of 10 Old 04-30-2002, 07:02 PM
You shouldn't need a new clutch yet unless you absolutely beat your car. My 97 Cobra has 60K miles on original clutch and it is still going strong--and I don't drive it like a little old lady either. Take it to a good shop and have it looked at. Just my $.02
SSSS97 is offline
post #9 of 10 Old 04-30-2002, 07:52 PM
if you drive a lot of short trips, your clutch cable could be fraying or dry. more of a pain crawling around underneath to change. good luck bobn
06 gt auto
bobn is offline
post #10 of 10 Old 05-01-2002, 09:31 AM Thread Starter
Thanks for the input guys! I'll try looking under the car and check the cable first.
Clutch problems? Or shifter? Or tranny?? Dirty Sanchez SVT & DOHC 0 07-28-2005 12:07 PM
96-98 Cobra Maintenance Schedule BlueOvalDriver SVT & DOHC 3 07-13-2003 08:00 PM
clutch problems!! please help!!! tording General Mustang Tech 3 10-21-2002 11:15 PM
Long term fuel trims maxed at+25%, what does this mean? 99SaleenS281 GT & SOHC 68 07-15-2002 08:12 AM
Clutch Problems...Help! Paul97BLKGT GT & SOHC 1 03-28-2002 12:18 PM
