Is there a down side to packing the trac loc clutches tight? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-25-2002, 08:58 AM Thread Starter
I will be replacing my diff clutches soon and need to know if anyone has had a problem after they changed the order of the clutches and making the limited slip tighter??
Dwayne
46GTSblown is offline
post #2 of 2 Old 04-25-2002, 09:53 AM
As always the S spring is a real bear cat to get in but that is always a problem.
Mine has worked fine and not worn out yet.
The stock setup had about 15k on it when slipping. I have about 30k on the added clutch setup with no problems yet.
Get some strong and patient friends to help you.
BlackCobraPilot is offline
Want To Buy LOOKING FOR A 7.5 TRAC LOC GOODOLEBOY84 Drivetrain Parts 3 05-22-2012 04:48 PM
trac loc is clicking Chris Smith General Mustang Tech 2 03-08-2005 08:25 PM
FMS 31 Spline Trac loc FS & 3.73 gears mulage Drivetrain Parts 0 02-16-2005 10:12 PM
Ford Racing 31 Spline Trac Loc w/ 3.73 Gears mulage Drivetrain Parts 2 01-05-2005 11:34 AM
SUPER trick/tip in installing your passenger side LONG TUBE header... Cobra Jet NJ General Mustang Tech 3 08-03-2003 11:17 AM
