Changing brake pads!! HELP!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-25-2002, 12:32 AM Thread Starter
Can someone give me some detailed instructions on how to replace the pads on a 1999+ Cobra? I got the calipers off etc and put the pads back in but i cant get the mounting bracket onto the caliper again. There is a little bar with washers on either end which fits in the end which I cant figure out how to get in. Someone please help!
THanks
Pat
WickedSnake is offline
post #2 of 2 Old 04-25-2002, 03:15 AM
All you do is hook the end with out the bar into the caliper and then swivel the caliper down and push the other end in far enough to push the bar through the resulting hole at the other end. Then install the washer and install the e-clip to hold it in place.
Hope that makes sence to you.
Good luck, Dwayne
46GTSblown is offline
what is maintenance worth to you? carpediem50 Lounge 20 04-29-2009 08:34 PM
1 set of pagid rs4 -2 brake pads, for Mustang/viper brembo gr8_96gt Suspension 6 03-20-2009 04:15 PM
What's everyone using for replacement brake pads on their Cobras? Cobra Jet NJ 94/95 Tech 11 09-07-2005 02:19 AM
help changing rear brake pads justanotherblackgt 94/95 Tech 4 12-21-2003 02:11 AM
Need help changing '98 GT brake pads kuma GT & SOHC 5 03-17-2002 02:03 PM
